Author: Subject: MOT Emmisions Q 's ??
megastu
posted on 24/3/10 at 05:27 PM Reply With Quote
Hi Folks,
Trying to get my car mot'd whats the scoop with emmisions testing ??
My car is a
Westfield MegaBlade
Age related plate (52 Plate)
Engine is a 1992 893cc Blade
What kind of emmisions test does it need ??
Visual smoke test ??
Co2 ??
None of my local garages seem to know,
Thanks, Stuart
"Its a bike with four wheels "
blakep82
posted on 24/3/10 at 05:30 PM Reply With Quote
def shouldn't be visible smoke. i think, when it comes to MOT, they put your cars details in the system and it should tell them on there what it should meet. it should go on the gas analyser. if the garage wants to do visible smoke then i wouldn't complain...
________________________
megastu
posted on 24/3/10 at 05:32 PM Reply With Quote
One of my local garages said it would just be a Co2 test with a 3.5 % pass or something like that.
blakep82
posted on 24/3/10 at 05:35 PM Reply With Quote
well, i *think it should meet whatever the standards were for the year of the car (2002?) if it was 3.5% then i think thats what it should be, but their system should tell them
have a look on here
http://www.motuk.co.uk/manual_730.htm
[Edited on 24/3/10 by blakep82]
neilj37
Doesn't it say on your V5 what the requirements are, pretty sure mine did ??
megastu
posted on 24/3/10 at 05:40 PM Reply With Quote
Nothing on my V5c stating Emmisions,i think it will just be tested as per requirements for a 92 engine !!!!
Regards
bodger
posted on 24/3/10 at 05:45 PM Reply With Quote
I remember it being said that one of the advantages of a Q plate was that it was just a visible smoke test since it was of undefined age, although some testers still argued it went on the year of the engine. I'm not sure what the deal is now that the MOT process is all computer driven. I was hoping nothing had changed 'cos I'll end up on a Q plate but I have a feeling it has.
COREdevelopments
posted on 24/3/10 at 06:05 PM Reply With Quote
Here is the updated mot emissions flow chart. bottom right states about kit cars.
emmisions linky
Rob
also below is quoted from the mot bible itself. it could be handy.
"Vehicles Fitted with a differnt engine
Test according to which is older, engine or vehicle.
e.g. A 1995 car fitted with a 1991 engine (of whatever make), test to 1991 standards for emission purposes.
Note: The onus is on the vehicle presenter
to prove engine age."
Brommers
posted on 24/3/10 at 06:33 PM Reply With Quote
Should be tested to the age of the engine, provided you can prove it's a 1992 engine. IIRC that's 3.5% CO and 1200ppm HC.
rsmith95uk
posted on 24/3/10 at 07:46 PM Reply With Quote
my V5 states under section 3 - Special Notes "SVA Cert Issued 09 08 2005 Emission Limit - %CO 4.5; HC 0.12.
This is for a 1986 2 litre Pinto - Q Plate.
Ray
[Edited on 24/3/10 by rsmith95uk]
deltron63
posted on 24/3/10 at 08:44 PM Reply With Quote
Visual smoke test only on mine, the joy of a Q plate
Bluemoon
posted on 24/3/10 at 08:56 PM Reply With Quote
Quite clear to me:
"For emissions purposes only, kit cars and amateur built vehicles first used
before 1 August 1998 and Wankel rotary-engined vehicles first used before
1 August 1987 are to be considered first used before 1 August 1975.
Kit cars and amateur built vehicles first used on or after 1 August 1998 ("S"
reg) are required to obtain Single Vehicle Approval and should be tested to
the limits stated on the log book / registration certificate."
From MOT link given above.
Dan
Brommers
posted on 25/3/10 at 11:03 AM Reply With Quote
Except, of course, that the V5 quite often doesn't have any limits on it, and when it does they're quite often wrong. And will inevitably be wrong if you change the engine for an older one, or if you have Q-plate (visual smoke only test).
