Author: Subject: Painting MK Alu interior trim/U trim
Kriss
posted on 29/3/10 at 12:20 PM Reply With Quote
Tried this at the weekend with Black hamnmerite smooth.
the result were terrible. I have used Hamerite before with great results, this was just terrible. The paint was just getting pushed around, tried 5 brushes all with crap results.
Thinking i need to strip with paint stripper and then prime perhaps or creat a key?
any advice? I know its comes in rattle cans if thats easier?
Tinks1
posted on 29/3/10 at 12:25 PM Reply With Quote
If you are using Hammerite on Aluminium you need their special primer, otherwise is does just what you described.
jabbahutt
posted on 29/3/10 at 12:26 PM Reply With Quote
is it because it's made of aluminum? if using hammerite try the special metals primer which is like red lead colour. Paint sticks to that no problem
skinned knuckles
clean thoroughly, use a good etching primer to provide a proper key and apply in several thin coats. you will always get a better finish if you spray rather than brush.
i'll never forget the words of my college lecturer. "the end result will be directly proportional to the time and effort spent in preperation"
he wasn't wrong.
A man isn't complete until he's married, then he's finished
INDY BIRD
posted on 29/3/10 at 05:44 PM Reply With Quote
hi yes need an acid etch primer 1st,
or powder coat them it cost me £15 to do mine not expensive and results are great,
link to advert of my car some pics of the trim there,
http://www.pistonheads.com/sales/1376210.htm
hope this helps
[Edited on 29/3/10 by INDY BIRD]
Jimtay07
posted on 7/7/10 at 03:26 PM Reply With Quote
If you have the money it may be better to buy the GRP side panels from MK, think its £204 for both side panels, mine were painted but the finish was awful,
Hope this helps
James
