Author: Subject: 989 Blade strange problem??
FFTS
posted on 29/3/10 at 02:02 PM Reply With Quote
Talking to someone who may be selling a 989 carbed blade 7 and he said this to me..
"Tell ya what I do find, if you don't start the car for like a month the
spark plugs give up and have to be replaced. "
Any ideas on this one or heard of it before?
Chris.
dean100yz
posted on 29/3/10 at 02:07 PM Reply With Quote
Does sound strange - maybe cos the latest blade lump is efi...
Or is it a 918?? Mine can be left months on the trickle charger & still starts instantly on the button with choke
ReMan
989?
Perhaps 919 on carbs.
Common enough issue, they are very sensitive to flooding/wetting the plugs.
Once this has occurred it's difficult to dry them on a bike battery without flattening it.
I've never changed a set yet, dry them over a gas ring put them in warm, sorted.
Send his old plugs my way
[Edited on 29/3/10 by ReMan]
FFTS
posted on 29/3/10 at 02:17 PM Reply With Quote
I am told its is a 989 and on carbs but will check back with him.
Sounds interesting about the wet plugs but dont see why this should happen AFTER being driven, switched off and the not started for a month?
Chris.
posted on 29/3/10 at 03:11 PM Reply With Quote
Drain the floats when it's being parked up and then fresh fuel will be in there for the startup. Condensation in the floats and stale fuel will wet the plugs and then they are fubar, especially if using the Iridiums can be expensive.
Steve Hignett
posted on 29/3/10 at 03:17 PM Reply With Quote
Blade engines are susceptible to fouled plugs - in 8000 miles and approx 18 months, I changed mine twice.
Once straight after SVA as they fouled from being stop started (this was a new set I'd just put in), I swapped them back to the old set. Then did a service, had some running problems after quite a few miles, and then swapped back to the old plugs yet again!!!
ETA - this was on a 918/919 though. I suspect that this is also the engine being offered to you...
[Edited on 29/3/10 by Steve Hignett]
FFTS
posted on 29/3/10 at 05:12 PM Reply With Quote
Can you tell which model by looking?
[img]http://locostbuilders.co.uk/upload/eng-left.jpg[/img
Image deleted by owner
[Edited on 29/3/10 by FFTS]
Chris.
dean100yz
posted on 29/3/10 at 06:20 PM Reply With Quote
Yeah thats a 918 Blade. Looks like mine with the TTS filter on top!
deanwelch
posted on 29/3/10 at 07:43 PM Reply With Quote
"heat plugs up on gas ring".............lol reminds me of my rd125dx
ReMan
posted on 29/3/10 at 10:13 PM Reply With Quote
Yep!
It worked for various ancient and small 2 strokes i had and also for newer 4 stokes (cars andbikes) that needed "coaxing" into life.
Unfortunatly todays throw away society is happy to accept "put a new set of plugs in"
£30 A SET.
I'd try the cheap alternatives first.........
