Author: Subject: ATB LSD
ban1216
posted on 31/3/10 at 06:52 AM Reply With Quote
ATB LSD
As title i purchased this diff as a spare and have never fitted it ,when i got the diff it had 3.9 ratio crown wheel and pinion but the pinion was showing signs of cracking due to bad set up
I have stripped the diff and replaced the crown wheel and pinion with good second hand crownwheel and pinion also i have fitted a new crush spacer and diff oil seal All bearings are good timken items
This diff has a large flange but i do have a small flange available if required
IMPORTANT BIT
this diff has been rebuilt but not fully tightened ie it will need the preload to be set up properly hence cheap price
£325 plus delivery
blakep82
posted on 31/3/10 at 10:19 AM Reply With Quote
what axle is it for?
i didn't think atb diffs has a preload setting?
________________________
lsdweb
posted on 31/3/10 at 11:21 AM Reply With Quote
ban1216
Sounds like an English one - if it can I have first dibs please!
Wyn
ban1216
posted on 31/3/10 at 04:29 PM Reply With Quote
It is an english one and does need the preload setting for the crown wheel and pinion and also the spacer needs to be set up and crushed to the correct poundage and i am led to believe the 2 bearing carriers need setting to the correct distance apart
I think you may be mistaking preload with ramp angles on plate type diff
Any way
SORRY SOLD FIRST THING THIS MORNING SORRY
Dopdog
posted on 31/3/10 at 04:39 PM Reply With Quote
have to be quick to get a bargin
ban1216
posted on 2/4/10 at 04:08 PM Reply With Quote
FORSALE AGAIN due to lack of funds
lsdweb gets first refusal
aww999
posted on 2/4/10 at 05:00 PM Reply With Quote
If lsdweb doesn't want it I will definitely take it, cash waiting
ban1216
posted on 2/4/10 at 06:02 PM Reply With Quote
awww999 you got second dibs
where are you based ??
aww999
posted on 2/4/10 at 06:09 PM Reply With Quote
I'm near jnc 10 of the A1 (an hour north of London) but I travel about a fair bit for work. Whereabouts are you based?
ban1216
posted on 2/4/10 at 06:37 PM Reply With Quote
I am in warrington cheshire
lsdweb
posted on 4/4/11 at 07:35 AM Reply With Quote
Is it still available? I didn't have this topic on my subscribed list - sorry!
Wyn
