Author: Subject: Busa Intake Air Control Valve - What Does it Do?
sucksqueezebangblow
posted on 31/3/10 at 09:56 AM Reply With Quote
Hi All,
What does the 'Busa Intake Air Control Valve do? Its the vacuum actuator and flap inside the air box and associated gubbins. Does it effect performance or is it just for emissions?
Has anyone bothered with it on their BEC?
If I don't need it can I simply disconnect the Vacuum Control Solenoid Valve and associated vacuum pipes (capping the vacuum connector on the throttle body of course) or will this cause the ECU to throw a wobbler?
[Edited on 31/3/10 by sucksqueezebangblow]
minordelay
posted on 31/3/10 at 04:43 PM Reply With Quote
It's to control the air flow into the airbox as far as i'm aware and utilise the ram air effect.
I've not used it and have just disconnected it on our K5.
I have seen on a Austrailian buggy forum something about a resistor being needed, maybe on later models. Some good info there which may sort you out.
http://www.wasuperlites.com/forum/viewtopic.php?f=15&t=320
SJL
posted on 31/3/10 at 07:29 PM Reply With Quote
On my Megabusa I deleted it as I am not using the standard airbox so no need for it.
I actually just taped it back into the loom I think.
I can send you the Westfield loom modification instructions if you want which covers all the required mods.
cosmick
posted on 31/3/10 at 08:43 PM Reply With Quote
The purpose is to maintain higher air speed at low throttle openings. This was the method employed bfore secondary throttle butterflies were thought of. It will run perfectly well without it if you intend to use the original airbox. Yes you can disconnect all the vacuum and electrical connections and it will not bring on any FI warning either. See my photo archive of how I have used the Hayabusa airbox. It is great for low induction noise and good for power if you make a cold forced air intake in the bonnet.
If it can't be fixed with a hammer then its probably an electrical problem.
Frosty
posted on 31/3/10 at 10:43 PM Reply With Quote
Mine's in the bin
sucksqueezebangblow
posted on 6/4/10 at 09:12 AM Reply With Quote
Excellent, thank guys! SJL I've sent you a U2U!
SJL
posted on 6/4/10 at 08:32 PM Reply With Quote
Hi Clive email sent
Regards
