Author: Subject: putty to bung jets up?
FASTdan
posted on 9/4/10 at 12:21 PM Reply With Quote
I've read somewhere on here about putty supplied with jetting kits for bunging up the air bleeds on bike carbs - what sort of putty is this and is it available from all good book stores?!
Seems like with these bunged up with cocktail sticks our ZX9 carbs fuel our 2.3 quite well - certainly in gears 1-3 but not had a chance to get a long run in 4th + 5th yet.
big-vee-twin
posted on 9/4/10 at 12:23 PM Reply With Quote
I used liquid metal, can get it from Halfords for about £5-6. Its an epoxy product.
http://www.triangleltd.com
speedystew
posted on 9/4/10 at 12:52 PM Reply With Quote
i got some pins with the dynojet kit i got from holeshot to block the air correctors off on my blade engine
rayward
posted on 9/4/10 at 01:05 PM Reply With Quote
can you not solder them up ?
Ray
r1_pete
posted on 9/4/10 at 01:16 PM Reply With Quote
I wouldn't put anything gloopy in there, who knows where it can run, Find some metal rod which is a good push in fit.
You can file it down if too big in the drill chuck.
andylancaster3000
posted on 9/4/10 at 02:46 PM Reply With Quote
2nd the solder comment. Works a treat and easy to remove if needs be.
Obviously you need to be able to extract the jets to do this...
[Edited on 9/4/10 by andylancaster3000]
Bladerunner
posted on 9/4/10 at 03:08 PM Reply With Quote
Hole blockers
If you use the rod that is left over from a pop rivet it works a treat with some araldite
Adventure before Dementia
RichardK
posted on 9/4/10 at 05:55 PM Reply With Quote
Boggs use small pieces of that ali welding/solder rod wire type stuff, just a few turns on the grinding wheel to put a point onto it and then just tap it in.
Rich
Gallery updated 11/01/2011
lotusmadandy
posted on 9/4/10 at 07:13 PM Reply With Quote
I always run an m3 tap down the jet,then fit m3 grub screws,
I have done 6 set of carbs the same way.
