Author: Subject: mx5 engine
Stuart_B
posted on 11/4/10 at 07:52 PM Reply With Quote
mx5 engine
hi all, some off you may know that i went though a duratec build, then had to sell it as the insurance issues, so tonight i just picked up a 1.6 mx5 engine and box.
the plan is to go in place off the 1.6 pinto, it is lighter and more powerful.
i will start buy bits through the summer to make the winter swop over as little time as possibly.
the engine
engine
engine
engine
engine
the box
gearbox
gearbox
the engine and box
engine and box
engine and box
and few bits
bits
bits
cheers
stuart
Guinness
posted on 11/4/10 at 07:55 PM Reply With Quote
Keep us posted. I'm seriously considering swapping the kwak engine out, and sticking an MX5 in this winter too!
Mike
Stuart_B
posted on 11/4/10 at 08:02 PM Reply With Quote
will do, the best bit all that for it was only 30pounds.
the same guy said i can have the ecu, the prop shaft and the wiring loom for free.
so this engine swap should be on a budget.
stuart
posted on 11/4/10 at 08:05 PM Reply With Quote
I have a 2-year old 1.8 MX5 engine / boxin the garage.
It's interesting to compare them the MZR set-up to the Duratec... far more gizmo's bolted onto the Mazda unit - I suspect most are to aid the VVT system!
Mines for sale BTW!
It's Evolution Baby!
Guinness
posted on 11/4/10 at 08:54 PM Reply With Quote
Mines for sale BTW!
For £30? I'll take it!
posted on 11/4/10 at 09:10 PM Reply With Quote
£30... yer havin a larff!
£47.87 and not a groat less!
perksy
Their a Nice engine and the Gearbox has one of the sweetest changes around
For the money, that's a real bargain
iti_uk
Builder
Posts 163
Registered 13/10/08
Member Is Offline
Photo Archive Go!
Building: The KLMX-5 ('97 MX5 w/Mazda KL 2.5L V6)
posted on 11/4/10 at 09:58 PM Reply With Quote
What year is that 1.6? If it's <'93, check to see if you have the short nose crank version - they can be troublesome with the keyway wearing away...?!
Very tunable engine - those B6's were designed for forced induction, so have oil squirters under the pistons as well as a few other choice design features, and are a very capable bottom-end.
Shame I weighed my '97 1.6 in at the local scrappie - but it was kaput anyway.
Good luck with it, it should be a nice little gem when you get it running.
Chris
FASTdan
posted on 12/4/10 at 06:42 AM Reply With Quote
Good to see you havent let the insurance issue put you off!
Will be an interesting conversion I am sure, keep us updated.
boggle
posted on 12/4/10 at 07:43 AM Reply With Quote
airhead on here is going to be doing a mx5 based locost, so im sure he will be interested....
u2u me for details
neilj37
posted on 12/4/10 at 07:47 AM Reply With Quote
You planning to use that seat in your car? Very locost
Stuart_B
posted on 12/4/10 at 06:03 PM Reply With Quote
hi, thanks for the advice Chris, i think it is, but i will make sure.
it is not that much less a 2.0.
i do like the tuning potential of these engines.
cheers will keep it updated
stuart
note to add, the seat is for my dad to seat on if he is out there with me.
[Edited on 12/4/10 by Stuart_B]
iti_uk
Builder
Posts 163
Registered 13/10/08
Member Is Offline
Photo Archive Go!
posted on 13/4/10 at 11:19 AM Reply With Quote
it is not that much less a 2.0.[Edited on 12/4/10 by Stuart_B]
Swivel chair - not just a locost solution - useful for parking, checking blind-spots, getting in/out. I say genius!
If you want a good place to check for engine advice on that model (moreso the 1.8L BP), check here.
Chris
