New Topic New Reply
Author: Subject: seatbelt mounting at rear
david cromie
posted on 8/5/04 at 11:30 PM Reply With Quote
I have just purchased a set of cobra roadster 7 seats. When mounted to the floor the sear holes are 4.5 inches above the mk sear anchor holes. It appears the sva man wants the belts to be coming straight out of the seats slots. any ideas. The only way around the problem that I can see is to weld a tube the same size as the roll bar across the roll bar and put threaded inserts and weld up. would this be ok for mr. sva man. David. Any photos would be great
zetec
posted on 9/5/04 at 05:03 AM Reply With Quote
I passed fine with Cobra 7s in and Indy. I don't think there is a problem with difference in height, unless a new rule has come in.
greggors84
posted on 9/5/04 at 04:11 PM Reply With Quote
I think the harness mounting point has to be higher than the back of the seats only if there are no harness holes in the seats. If you have harness holes there is no problem i think.
Chris
The Magnificent 7!
macspeedy
posted on 9/5/04 at 05:42 PM Reply With Quote
I think its mainly a problem for chaffing on the belts no sharp edges then no problem, strength of seats is also a problem then
Mix
posted on 9/5/04 at 06:57 PM Reply With Quote
I think if the mounting points are lower than the harness holes the seat is considered to be a structural member and as such would probably fail. The horizontal bar option across the roll bar seems to be the easiest option, at least it's the one I intend to use. (at the moment)
Mick
david cromie
posted on 9/5/04 at 10:52 PM Reply With Quote
seats
thanks lads for all your help. Checked with an other indy person and found that his openings for his seatbelts are lower than mine, and that is where the problen arises. david
New Topic New Reply
