Author: Subject: Any Good?
omega0684
posted on 12/4/10 at 10:19 PM Reply With Quote
Any Good?
Lathe Linky
ReMan
posted on 12/4/10 at 10:34 PM Reply With Quote
Looks a neat little set up.
I have always been a bit concerned that the milling attachments may be less than great though, but happy to be told different
iDENTITi
posted on 12/4/10 at 11:20 PM Reply With Quote
Doesnt look like a bad lathe to be fair.
Nice selection of tools too, and most look carbide tipped which means no regrinding.
clairetoo
posted on 13/4/10 at 05:54 AM Reply With Quote
Not bad for a `toy' lathe - but very small , and has no power feed .
If you dont mind swopping the motor for a single phase one , this would be a much better buy .
Its cuz I is blond , innit
Claire xx
Will weld for food......
rf900rush
posted on 13/4/10 at 06:37 AM Reply With Quote
I have a Warco (without the mill) version.
Very usefull but difficult when accuracy is needed.
Never regetted getting it but always want a bette one.
posted on 13/4/10 at 07:44 AM Reply With Quote
A friend has one - very good, as long as you understand its limitations (you could say the same about most things).
It's fine for model engineering, and any car jobs of a similar scale (turning bushes, etc.). You couldn't turn brake drums or discs though!
If you've never owned a lathe before then it would be an excellent one to learn on. When you've developed some knowledge and skills then you could upgrade to something better, and still have something to trade in.
bartonp
posted on 13/4/10 at 07:47 AM Reply With Quote
Go and look at one 'in the flesh' at your local www.machinemart.co.uk
franky
posted on 13/4/10 at 08:11 AM Reply With Quote
I've got a seig(red&black) lathe and mill that i'd be willing to sell, Digital readouts/powered feeds/variable speeds(not just the 5-6 you get with belts), on a stand. Little use as I only built a couple of steam engines with it.
I did have the flow reports from when I bought it, very very accurate, a good step up from the chester/warco/clarke stuff.
Bluemoon
posted on 13/4/10 at 10:14 AM Reply With Quote
Lot also depends on how much room/cash you have, and don't under estimate how heavy a "good" secondhand machine can be..
Dan
posted on 13/4/10 at 10:19 AM Reply With Quote
I know what you mean - my Colchester Student cost me £200, then £100 to shift it into my garage on the back of a lorry. It's 6ft long, and requires 6ft total space fore and aft to operate properly. It also weighs more than my Locost!
And any engineering shop would regard it as a beginner's training lathe...
[Edited on 13/4/10 by David Jenkins]
big_wasa
posted on 13/4/10 at 12:44 PM Reply With Quote
I am with you on that, I had a better one but needed the space for the car.
The Shootist
posted on 17/4/10 at 04:18 AM Reply With Quote
The problem is....
The problem with combo mill/lathes is that they don't do either very well. If you have space and funds a seperate set up is always better.
Always buy as much machine as you can manage. You can make small parts on a big machine, but you can't make big parts on a small machine.
