New Topic New Reply
Author: Subject: Seven_Monkey - Build Thread
Seven_Monkey
posted on 15/4/10 at 11:18 AM Reply With Quote
So thought I'd start this up from speaking to various people, not only to update everyone on my progress and to get thoughts but as an incentive to keep on with it and get it done this year.
So first post is the list of things to do - I'll update this post as they're done and repost and progress pics.
*Handbrake Cable Brackets
*Seats In/Extra Rails
*Steering Column Brackets
*Steering Column Extended
*Front Wing Supports
*Plate for Driver Footwell
*Headlamp Supports
*Brake pipe brackets
*Nose cone Brackets
*Bonnet Brackets
*Neg Engine Bay Bolt
*Captive Nuts to Chassis
*Horn
*Coil
*Fuel Pump
*Rear Arch Supports & Plate
*Spare Wheel Supports
*Roll Bar
*Scuttle Frame
*Scuttle fitted
*Strip Down Chassis & paint
*Fuel Tank fabricated
*Fuel Lines in
*Brake Lines in
*Exhaust Fabricated 4-2-1
*Windscreen supports
*Body Panels
*Pedals Fitted
*Bonnet Fabricated & Fitted
*Dashboard Set out
*Wiring Loom
*Strengthen rear trailing arms brackets
*Front Hubs together
*Rear shocks fitted
*Check Axle oil
*1600 Recon/Rebuild
*Initial IVA requirements Check over
Rich
tegwin
posted on 15/4/10 at 11:30 AM Reply With Quote
*Headlamp Supports
*Nose cone Brackets
*Bonnet Brackets
*Take Massive Turd
*Remeber To Wipe
*Horn
*Coil
*Fuel Pump
*Roll Bar
*Scuttle Frame
*Scuttle fitted
*Fuel Lines in
*Brake Lines in
*Body Panels
*Pedals Fitted
*Dashboard Set out
*Wiring Loom
*Rear shocks fitted
*Check Axle oil
*1600 Recon/Rebuild
Rich
EFA
www.verticalhorizonsmedia.tv
Seven_Monkey
posted on 15/4/10 at 11:36 AM Reply With Quote
Good job that's on there...
Wondered why I was backed up!
DavidM
posted on 15/4/10 at 06:29 PM Reply With Quote
*Headlamp Supports
*Nose cone Brackets
*Bonnet Brackets
*Take Massive Turd
*Remeber To Wipe
*Horn
*Coil
*Fuel Pump
*Roll Bar
*Scuttle Frame
*Scuttle fitted
*Fuel Lines in
*Brake Lines in
*Body Panels
*Pedals Fitted
*Dashboard Set out
*Wiring Loom
*Rear shocks fitted
*Check Axle oil
*1600 Recon/Rebuild
Rich
EFA
What does EFA mean?
Proportion is Everything
iank
posted on 15/4/10 at 06:34 PM Reply With Quote
Originally posted by DavidM
What does EFA mean?
Edited For Accuracy
http://www.urbandictionary.com/define.php?term=efa
Anonymous
Seven_Monkey
posted on 15/4/10 at 07:24 PM Reply With Quote
tegwin thought I'd need reminding to drop the kids off...
Build Thread - http://www.locostbuilders.co.uk/viewthread.php?tid=134121
DavidM
posted on 15/4/10 at 08:17 PM Reply With Quote
Thanks, but I've lost track of this thread already, you're all talking in riddles. Do you speak English?
tegwin
posted on 16/4/10 at 08:11 AM Reply With Quote
Sorry... what was the question?
New Topic New Reply
