Author: Subject: cost of megajolt
deanwelch
posted on 15/4/10 at 06:03 PM Reply With Quote
cost of megajolt
hi guys does anyone know roughly how much a megajolt would be supplied and fitted........fitted being the most important..........2 litre pinto with twin 45s, standard distributor and electronic ignition.........near sunny great yarmouth would be nice...........thanks in advance.
lotusmadandy
posted on 15/4/10 at 06:11 PM Reply With Quote
If you are running a standard distributor and electronic ignition,why do you want a megajolt??
Autosport labs sell megajolt for about £110 delivered.
[Edited on 15/4/10 by lotusmadandy]
deanwelch
posted on 15/4/10 at 06:36 PM Reply With Quote
no vacuum advance as running twin 45s.............but a full kit is around £300 ie tps edis pick up wheel megajolt but mainly a price and somewhere that can fit it..........
posted on 15/4/10 at 06:40 PM Reply With Quote
It's the "someone who can fit it" that's the problem. It does require a fair bit of mucking about and user input, which most commercial garages wouldn't want to know about.
Basically, it's a DIY system designed to be fitted and set up by enthusiasts.
deanwelch
posted on 15/4/10 at 06:55 PM Reply With Quote
enthusiast yes............skill set maybe not............maybe best to go for an aldon distibutor....
ashg
posted on 15/4/10 at 07:18 PM Reply With Quote
if you want to buy the bits and drive to me i will fit it for you. but im in kent. surely there is another lcb that will come round and help you.
[Edited on 15/4/10 by ashg]
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
norfolkluego
posted on 15/4/10 at 07:26 PM Reply With Quote
Dean,
Megajolt is an absolute doddle to fit. I've just done it and if I can anyone can. It really is very simple. Really good clear instructions on the Autosport Labs website and on the installation disc. I bought mine from a fellow Locoster for £120 new (and built).
Are you worried about building the kit or installing a finished kit, if it's the latter, don't be, it's easy.
[Edited on 15/4/10 by norfolkluego]
deanwelch
posted on 15/4/10 at 07:46 PM Reply With Quote
looks like a job for this winter then..... i shall make a list of the bits i need........pick them up on a trip to the scrapies........and have a look at other installs this summer at shows......do some more research.....and give it a go myself.......cheers guys...
deanwelch
posted on 15/4/10 at 07:52 PM Reply With Quote
does anyone on here go to eastanglia kit car club run a pinto with a megajolt ?
matty_64
posted on 15/4/10 at 08:07 PM Reply With Quote
you need to speak to flack monkey.he lives near kings lynn and is a member of eakcc.i think thers a couple of cars in the club running ms.come along to a meet youll be more than welcome.
deanwelch
posted on 15/4/10 at 08:19 PM Reply With Quote
met flakmonkey last meet....nice supercharger......i think ms megasquirt is replacement for injection system on newer engines not megajolt for older pintos will speak to him at stoneleigh i think he his camping......
Danozeman
posted on 15/4/10 at 08:55 PM Reply With Quote
Theres plenty of stuff about the net for pintos with megajolt and plenty of people on here with it.
You will need:-
trigger wheel
Crank VR sensor and some sort of mounting bracket
EDIS unit from early escorts with the plug
zetec coil pack with plug
and megajolt unit.
It is easy to set up, the wiring is a piece of cake. Ill come and give you a hand if you get stuck.
Failing that, get an aldon igniter dizzy. A bloke i know fitted one in his 2 litre pinto tiger, works well.
Dan
mcerd1
posted on 16/4/10 at 07:17 AM Reply With Quote
Originally posted by deanwelch
.......i think ms megasquirt is replacement for injection system on newer engines not megajolt for older pintos....
if he can sort out MS then he can do MJ in his sleep :lol:
this site gives you a good idea of whats involved: (its an older version of MJ but you still fit it the same way)
http://www.cate1.co.uk/megajolt/index.php
as for the bits you need, no more than £25 delivered for a trigger wheel
and the donor bits if you take them off yourself should be less than £40 inc all the wires and plugs that link it all together
(I got all my donor bit for £25 )
[Edited on 16/4/10 by mcerd1]
deanwelch
posted on 16/4/10 at 08:00 AM Reply With Quote
thanks guys...........see you at stoneleigh dan.......
