Author: Subject: Fuel Pressure regulator
thepest
posted on 29/4/10 at 09:49 PM Reply With Quote
Can someone recommend me one? I'm looking for one for a turbo application on a toyota MR2 (3S-GTE)
omega0684
posted on 29/4/10 at 09:57 PM Reply With Quote
you running JIC or Push On fittings?
Sytec do a performance one that can accomadate your needs but it aint cheap at £80.
You could get one of the cheap ones though on Ebay for about £25-£30
thepest
posted on 29/4/10 at 10:20 PM Reply With Quote
I'd have to customize my own fittings. I found a few on ebay but I have no idea whats good or whats not.
I'd rather go with something that someone has already tried and tested.
posted on 29/4/10 at 10:28 PM Reply With Quote
I haven't heard any bad experiences with the cheap ones generally sold on the bay for 25-30 even when used forced induction. I sure hope they work okay because that's what I'll be using (if my blown EFI thing ever happens!).
flak monkey
posted on 30/4/10 at 07:49 AM Reply With Quote
I am using a cheapy from ebay - no problems yet
As long as you keep an eye on your AFR you should be ok.
Sera
http://www.motosera.com
atspeed racing
posted on 30/4/10 at 08:54 AM Reply With Quote
we use and sell turbosmart FPR800 (also 1000 and 1200) available with push on, or JIC fittings. not cheap but they dont go wrong.
on forced induction engines where the fuel pressure regulator is used as rising rate, the fuel pressure regulator becomes a crucial part of the engines fuel system and should never be overlooked.
we can sell the sytec ones but we feel they are inferior, they are also known to make an annoying squeak.
a fuel pressure regulator is cheaper than an engine!!
- colin.
boggle
posted on 30/4/10 at 10:35 AM Reply With Quote
had several sytec (fse) regulator/ boost valves and never had a problem....
u2u me for details
cd.thomson
posted on 30/4/10 at 10:42 AM Reply With Quote
did you have to keep replacing them when they broke?
[Edited on 30/4/10 by cd.thomson]
Craig
boggle
posted on 30/4/10 at 10:55 AM Reply With Quote
haha...
sorry should have said on several cars....
u2u me for details
