Author: Subject: Oil leaking from bellhousing
FASTdan
posted on 5/5/10 at 07:06 AM Reply With Quote
Unfortunately our nice new duratec install is slightly flawed in that we appear to have transmission oil dripping out of the bellhousing.
Its deffo transmission as it has that distinctive smell!
Would I be right in assuming that this is going to be the input shaft seal?
Big job im guessing
flak monkey
posted on 5/5/10 at 07:20 AM Reply With Quote
Could be either the input shaft or the selector shaft.
If you fitted a new seal on the input shaft then its likely the selector shaft.
Input shaft seal is a 5 min job....but you need the engine out first
Sera
http://www.motosera.com
posted on 5/5/10 at 07:31 AM Reply With Quote
Did you remember and fit a spigot bearing to the end of crankshaft ?
Other wise it is the tranny input oil seal easy enough to fix. Ford specified a lower oil lievel because of leaks from this seal the oil revised level should be about 10 to 15mm below the level plug on a level surface.
FASTdan
posted on 5/5/10 at 11:41 AM Reply With Quote
Sweet! So that means its normal to leak if full to the filler level?
we fitted a bearing
posted on 5/5/10 at 12:04 PM Reply With Quote
we fitted a bearing
Normal for it to weep slightly over a high mileage if overfilled..
Mr G
posted on 5/5/10 at 04:25 PM Reply With Quote
What box are you using? If its type 9 you did use a gasket or sealer around where the layshaft Comes through the front of the box didn't you?
Cheers G
Edit - viewing on my phone so hard to see the whole thread that easy, as its duratec I pressume type 9 then
[Edited on 5/5/10 by Mr G]
FASTdan
posted on 5/5/10 at 07:32 PM Reply With Quote
Cheers G
Yeah we did seal around the selector - presume thats what you mean by layshaft?
Going back to Britishtridents comment, what relevance is the spigot bearing to leaks out of interest?
NEW danST WEBSITE NOW LIVE! Bike carbs, throttle bodies and more......
http://www.danstengineering.co.uk/
Mr G
posted on 5/5/10 at 09:51 PM Reply With Quote
No the selector comes through at the top into a recess in the bellhousing, the end of the layshaft is visible bellow it in the front of the gearbox casing. Standard gasket between bellhousing and gearbox encloses both areas which I've had trouble from before with leakage.
G
FASTdan
posted on 5/5/10 at 10:00 PM Reply With Quote
Oh sh*t lol. we never spotted that. I suspect that is our problem then.....
Mr G
posted on 5/5/10 at 10:32 PM Reply With Quote
Just to add that there a 2 different filler plug locations depending on how old the box is - newer boxes have a lower filler plug location compared to the older higher ones.
G
