Author: Subject: Wipers not parking
Motty
posted on 16/5/04 at 08:37 PM Reply With Quote
Wipers not parking
I have asked this question before but am still having trouble so can anybody help me please. I have a Mini wiper motor which I have changed the cam on so that it parks on the correct side, the problem is that it refuses to park at all. Both speeds are working and it stops but just will not park, I have changed the microswitch but this hasn't helped. I understand that the parking side of things should be live when the wipers are switched off but where should I get this live feed from. Any ideas please?
ady8077
posted on 16/5/04 at 09:48 PM Reply With Quote
Have a look at the attatched drawing
Its off the Tiger chat group
Adrian
ady8077
posted on 16/5/04 at 09:53 PM Reply With Quote
Dont think the link works
Go to http://autos.groups.yahoo.com/group/tigerracing/
And look in the files section, under wiring diagrams. Or u2u me your email
Adrian
Dusty
posted on 16/5/04 at 11:23 PM Reply With Quote
The tiger diagram shows the links well but doesnt show that the column or dash switch must connect 2 and 5 on the mini wiper motor when in the off/park position. There is a dedicated Lucas switch that does this or the standard sierra switch will do it if wired as shown. The washer wiring is not as shown for post 87 column switches.
zetec
posted on 17/5/04 at 07:37 AM Reply With Quote
Might be worth asking Premier Wiring. I fitted mine as per their loom and instructions and worked first time. Other thing to make sure is that the gear is able to contact the switch. When I stripped mine to clean and regrease I forgot to fit a washer that holds the driven gear in place, too much endfloat and it would not work the park switch.
Steve @ sVc
posted on 20/5/04 at 05:28 PM Reply With Quote
Motty
Have you looked in the wiper section of our web pages? www.s-v-c.co.uk.
Which switch are you using?
Call me if you like @ local call charge on 08 456 581 451
Regards
Steve @ sVc
