posted on 15/5/10 at 07:05 PM |
OT: Arse
I've just realised the 76mm holes I've drilled for my bathroom GU10 downlighters should have been 72mm so the inner bit of the light pulls
itself (due to the springed arms) into the loft and the glass + chrome bit falls down into the bathroom. Which isn't the plan.
So how can I add 2mm to the inside of a hole I've already cut-out? I could try just plastering it but it'll be a PITA to try and get a
constant depth all the way round and I suspect it'd crack off as soon as I put the lights in place! I wondered about no-more-nailing some 2mm
thick material (yet to be decided) to the inside of the hole in the ceiling (annoyingly it's lath + plaster so I can't just wack in a new
big bit of plasterboard.... If I could find some 72mm ID/ 76mm OD pipe I could glue a section of that in place but I suspect the chance is small!!
Any genius ideas? I did try asking the wife if she had any ideas but after 30 minutes of talking she still hadn't grasped why the lamp was
disappearing through the hole that was too big so I gave up hope......
Of course what I could do (seeing as I have access from the top of the lights from the loft) is to glue the two parts of the light together and well
and truly glue it to the ceiling and just change the bulbs (if I ever need to) by going up into the loft
deltron63
posted on 15/5/10 at 07:11 PM |
make spacer the size you want,cut a slot in the roof, slide the spacer through the slot and pull it down. job done
907
posted on 15/5/10 at 07:20 PM |
2mm thick ally strip cut 232.5 long.
Bend round a tin/pipe/bottle/etc to form a ring.
Two cuts 10mm apart in three places (6 cuts) and bend down to form tabs.
Insert from above so it sits on the tabs.
Blob of mastic. Job done.
Paul G
posted on 15/5/10 at 07:22 PM |
find some slightly bigger lights?!
iank
posted on 15/5/10 at 07:31 PM |
Wasn't just me thinking that then
Though 907's suggestion sounds like a good one to me.
Anonymous
posted on 15/5/10 at 07:39 PM |
yes, finding some 76mm lights would be the best option but yes, I do wonder whether something like the ali sleeve is an option.... Otherwise I
think the 2mm ali tube and a bit of epoxy to snot it in place might be the best option But yes- if I put the springs on top of the tabs it would
hold the whole shooting match in place
Tatey
posted on 15/5/10 at 07:50 PM |
What about drilling a fresh bit of wood the correct size, fixing it to the top of the ceiling (from the loft side), thus stopping the lights from
disappearing and then if necessary, find some kind of filler if there is a gap between the light and the original plaster board.
posted on 15/5/10 at 07:56 PM |
It's a good idea but it wouldn't work The flange designed to clamp up against the underside of the ceiling would still be able to pull
through the hole until it got to the bit of wood...
Tatey
posted on 15/5/10 at 08:02 PM |
What about sticking some more plasterboard or wood over the top of the hole from the loft side, plastering over the top of it from the bathroom side
so you have a nice flat ceiling again, and then drilling a new hole?
The wood should support the new plaster, which will stop it from cracking when the light is put back in.
[Edited on 15/5/10 by Tatey]
posted on 15/5/10 at 08:48 PM |
Yup, it's a tempting option. Only issue is the lath + plaster is about 30mm thick so with some plasterboard as well it'll be getting quite
thick for the short arms. Then again that will reduce the "pull" of the light up into the loft..... A good idea!
Ben_Copeland
posted on 15/5/10 at 09:07 PM |
Shame its lath & plaster.. you could cut some squares of plasterboard, drill the required size in them, then cut the squares into the ceiling and
plaster them in..
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
Jon Ison
posted on 15/5/10 at 09:08 PM |
sorted
keithice
posted on 15/5/10 at 09:49 PM |
A note of caution... I had to put in dropped ceilngs made of plasterboard as I was told downlighters can get hot enough to burn the lathes...
Smile and wave boys.... Smile and wave....
posted on 15/5/10 at 09:55 PM |
Not sure about the blue colour but it is a tempting issue. I'm certainly got to keep a very close eye on the laths when the lights are on!!!
Maybe cutting back and in-filling with plasterboard isn't such a bad option though
skinned knuckles
posted on 15/5/10 at 11:04 PM |
correct. i hope the lights you are fitting are the sealed units with a fire rating? have seen a couple of nasty house fires caused by these lights
now. be careful.
A man isn't complete until he's married, then he's finished
posted on 15/5/10 at 11:19 PM |
now. be careful.
But the fire rating is to do with how long they'll prevent a fire underneath the light travelling to the area above the light aren't they
IE they could glow cherry red and still have a fire rating?
oldtimer
posted on 16/5/10 at 11:13 AM |
New holes, just to the side, and plaster over the old holes ? how many did you cut???.....I have fitted expensive chip LED GU10 4-5w equivalents and
they run cold.
posted on 16/5/10 at 01:40 PM |
they run cold.
True- an option.... how bright are they though?
posted on 16/5/10 at 02:02 PM |
Okay. Here's the plan!
76mm O/D 1.6mm wall thickness ali tube. Cut a square piece of 12mm ply, use the 76mm hole cutter (in the bench drill) to make a nice square edged
hole, put a piece of the tube in the ply, glue it in place with some 24hr araldite. Then glue it onto the top of the lath + plaster using plasterboard
adhesive.
simples
And then probably chicken out and use some LED lamps cos they're pretty close to the beams!!
thefreak
posted on 17/5/10 at 03:15 PM |
So the holes are the same diameter as the lights? just fit some squares of plasterboard in the loft above the existing holes, drill new 72mm holes
(the correct diameter) and have flushfit lights.
