matt_gsxr
posted on 16/5/10 at 09:04 AM |
LED replacement bulbs, suppliers?
Hi there,
Anyone have a supplier of nice bright rear replacement bulbs. I see 1000's on e-bay, and read that the Halfords ones are not road legal so am a
little confused. Razman had a good thread a while back, but his supplier has disappeared.
I need them to have brake 21w and rear 5w in one for a land rover style holder. The power saving is in the rear bulb, but I want to be sure that the
brake-light is nice and clear (for obvious reason).
Also I am after sidelights, but I don't mind picking something e-bay ish for these as they aren't really safety critical.
I discovered that with the extra load on the alternator from my EFI, that at night the battery gets sucked dry. So I trimming power and every amp
counts (I should be able to get rid of the lamba probe which has a heating element so removing that should also help).
Thanks,
Matt
Lars
posted on 16/5/10 at 09:14 AM |
matt
i think i have some bulbs in the garage, I'll check and send you a u2u later
posted on 16/5/10 at 10:16 AM |
As far as I know, none of the LED replacement bulbs are E-marked, so not technically road legal. However, as long as they are bright enough and of
the correct colour you'd be very unlucky to have any problems in this area.
What is your Alternator rated at? Must be pretty tiny.
RazMan
posted on 16/5/10 at 10:58 AM |
He is still around ......
http://stores.ebay.co.uk/warden-jp2002_1156-1157-BA15S-BAY15D-Bayonet_W0QQ_fsubZ6QQ_sidZ70019414QQ_trksidZp4634Q2ec0Q2em322
One tip I can give you is that the red LEDs are by far the brightest and if you have a red lens in your stop/tail light it is much brighter to use a
red LED than a white one - the red lens filters out a lot of useful light from the white version.
Also try and get anything that mentions 'Luxeon' in the spec - these are the new generation of LED and many times brighter tahn the older
type (I found a Luxeon torch which is almost like a laser!)
p.s. I think the 13W stop/tail is what you will need - that's what I ended up with and they are even brighter than normal filament bulbs but a
lot depends on your reflector. LEDs are very directional and you really need as much light firing outwards to make full use of the reflector.
[Edited on 16-5-10 by RazMan]
Raz
matt_gsxr
posted on 16/5/10 at 11:22 AM |
Excellent replies, what a good forum.
Lars, yes please.
Mike, its the standard alternator on the gsxr1100. The bike used to have carbs that were gravity fed and a bike headlight. The only current draw was
a crude CDI unit and the lights. Now I have headlights, fuel pump, lambda probe, megasquirt coil drivers, megasquirt. I don't know the exact
amps. I do know that I drove 90miles in the dark (~6kRPM at ~70mph) to Llandow, and after stopping the battery was too flat to turn over the engine
(I had a spare battery so it wasn't a big problem).
Thanks Raz.
The hope is that I can nibble away at the current demands, it can't be that far off.
Matt
posted on 16/5/10 at 11:38 AM |
Doh, that would have been obvious if I'd had the sense to look at your profile!
Yes I can well imagine that is a fairly low output units. In the worst case would the alternator from a newer, fuel injected, Suzuki engine fit or
are they (as I suspect) completely different?
EDIT: Might be worth temporarily wiring in an ammeter to keep an eye on things while you get it sorted. You can get even get ones that simply clip
over the wire, so no cutting or connections to be made e.g.
Durite
[Edited on 16/5/10 by MikeRJ]
ChrisW
posted on 16/5/10 at 11:52 AM |
You could also switch to HID headlights. Again, not strictly road legal, but they'll save you ~40% energy from the headlights.
(Aftermarket HIDs use 35w all the time, compared to 55w on full beam and 60w on main for incandescent)
EDIT: I've used ultraleds.co.uk a few times. They're not the cheapest, but I guess you're paying for someone else to try all these
eBay ones out and select the best. At least with them you know you'll get the item as it is described.
Chris
[Edited on 5/16/2010 by ChrisW]
eddie99
posted on 16/5/10 at 11:58 AM |
U2U sent
http://www.elitemotorsporteng.co.uk/
Twitter: @Elitemotoreng
Facebook: http://www.facebook.com/pages/Elite-Motorsport-Engineering/153409081394323
matt_gsxr
posted on 16/5/10 at 12:30 PM |
Mike,
The water cooled gsxr1100 shares parts with the earlier air cooled gsxr1100 which dates back to 84. It includes the regulator and rectifier in the
unit.
When they pulled the plug on the gsxr1100 (too heavy and uncompetitive to sell) they went away for a couple of years before bringing out the gsxr1000,
which was totally different and doesn't share anything (until you steal the throttle bodies etc and put them on your gsxr1100 ;-). The rf900
has the same alternator, but never was fuel injected so probably the same part as the old GSXR1000.
In the gsxr1000 they have a separate regulator circuit and the generator is tiny (not quite sure how it all works but it won't fit).
The old air-cooled gsxr engine lived on in various models (Suzuki Bandit's aka gsf) but they kept these on carbs for ages. I need to look at
the later EFI gsf models. Maybe post on the oldskool suzuki forum to see if there is a more meaty alternator.
Matt
RazMan
posted on 16/5/10 at 12:55 PM |
+1 for HID units - bloomin bright too! They take about 20 mins to fit and I reckon they were my most significant power saver on my car - great for
small alternators like ours. Unfortunately it is not practical to have them as main beams due to the time delay during warm-up.
Raz
matt_gsxr
posted on 16/5/10 at 03:21 PM |
HID is a good idea, but the H4 ones sound a bit dodgy, and I don't like to break the law for no good reason. It did cross my mind that I could
just put in dipped lights, as main beam isn't really that important these days as the roads are so busy.
Mikes suggestion seems to be bearing fruit. The gsxr1100 regulator is rated at 25amps, but the later 2001-2004 gsf1200 is rated at 405W (32Amp).
(this is the same output as the early Busa's if the internet is to be believed)
So, if I can save a couple of amps with some LED lights, and gain a few amps with an improved alternator, then I can stop worrying.
Doing some current accounting, actually I'll do it in Watts for my set-up;
headlights 2x55W = 110W
sidelights 2x5W =10W
tail lights 2x5W = 10W
Injectors* 48W * duty cycle = 12W
Fuel pump = 120W
Ignition drivers 8A*duty cycle = 72W
Total power = 334W => 28Amps
300W = 25A. So I am losing 3Amps, which from a 8Ah battery is too restrictive.
I've ignored the little gauge lights, megasquirt, sat. nav. power and don't know the duty cycle on the lambda probe heater.
*4x12Ohm injectors. Based on motorway running at 25% duty cycle.
**2x3Ohm Dyna coils running wasted spark, 75% duty cycle (I could drop this to save some juice, but big sparks must be a good thing)
Nice when the theory fits the practice. Time for some new lights and an e-bay hunt for an alternator.
Thanks for your help with this,
Matt
Canada EH!
posted on 16/5/10 at 03:37 PM |
How about totally out of the box thinking. In years past some racecars used a pulley on the driveshaft to drive an alternator.
Your problem seems to come while driving, not while stopped.
ChrisW
posted on 16/5/10 at 04:09 PM |
I have three sets of H4's on three different cars. They're spot on IMHO.
For those that don't know, they have a small solenoid in the base of the bulb that moves the light emitting part between the two H4 positions to
switch between high and low beam.
In practice, the switch is instant, especially compared to a regular halogen. The only downside is they make a clunking noise as you switch, but in a
seven it's unlikely you'd hear that.
If you're down this way (Gerrards Cross, bottom of the M40 from you) you're welcome to pop over and see them in action.
Chris
posted on 16/5/10 at 04:24 PM |
10A for a fuel pump? Really? My ST1100 jobby pulls 5A (just as well cos I've only got 28A to play with....).
My answer is to wallop a pulley on the front of the crank pulley and run a blower and alternator of it (when I eventually get round to it!!)
matt_gsxr
posted on 16/5/10 at 08:40 PM |
Ben,
It does sound a lot. The value was from memory, so I am not certain. It is a pain to measure as my ammeter only goes to 10A and surge blows the
fuse.
The pressure from the pump is 43psi and the flow rate is maybe 2litres per minute, and doesn't slow down once the rail is at pressure. So the
work done is not inconsiderable. I know it draws a fair bit more current than my old carb pump (although that only put out 3psi, and had a pulsed
current demand owing to the way that those pumps work).
Is yours fuel injected or carb?
I will measure and post it.
Matt
matt_gsxr
posted on 17/5/10 at 09:23 PM |
Hot wired the voltmeter tonight and measured the current into the fuel pump.
3.5Amps not 10A
I guess I need to have a look to see where I'm losing all my amps. Maybe the alternator isn't running on all phases.
I ordered a pair of HID and some nice powerful LED brake lights, and some bog standard sidelight LEDs.
I have had battery problems in the past so anything that moves me in the right direction is a good thing.
Matt
matt_gsxr
posted on 26/5/10 at 09:44 PM |
35W HID drawing too much current
So, as a follow-up,
The rear lamps suggested by Razman turned up and they are excellent. I had tried some other ones, but to be frank the brake lights were inviting an
accident. Razmans ones are the business (shipped from China, so not that quick).
The front sidelights turned out to be nice little units (and cheap).
So, the sidelights (from and rear) now draw 0.5A. This is down from around 2A. Also the break lights are still good, and the sidelights are actually
a bit brighter FWIW. So all good there.
The HID kit arrived. I ordered a 35W, 6000K set, in bi-xenon H4. This uses a solenoid to move a shield to switch between high and low beam. Took a
few days to arrive (China again), was a bit cheap and nasty when it arrived, but it was cheap (£46 including shipping and everything). No
instructions (which may have been because it was opened in customs, or maybe because its crap. So, doing an install when you know the thing can
generate 30kV with no instructions (at least it wasn't raining yesterday).
Installed it over the last couple of evenings (not made easier by having no earthing points on the glassfibre bonnet) and some of the wiring (the
little connectors to the solenoids for dip/main) are of poorer quality than the rest of the kit, which isn't too awful.
Disappointingly, it isn't plug and play. I had to run a power lead back to the battery (the start-up currents are very high). So 20-40 mins,
was really about 3-4hours. once holes had been drilled and all the bits mounted.
So, fired them up and they are nice and bright, but not evil. All good so far.
Then I measured the current.
7.7A on dipped (46W), 8.4A on main beam. THere is a further 0.1A going into them from another line (probably powering some control circuitry).
Now, call me a pedant, but 35W x 2 at 12V is 6A. The whole point of this exercise was to drop the current, so I have saved 1.5A when I was expecring
to save 3.5A. I am sure that most people don't care about an Amp here or there, but I do.
The chap (dizaa8) is going to get some questions from me and likely a negative feedback if he can't sort it out, I am sure he will think I am
mad, but I can't be sending them back (£37 postage is what he charged, £9 for the item) and messing around.
Any thoughts appreciated.
Matt
RazMan
posted on 26/5/10 at 10:30 PM |
Matt, Are you measuring the current when powered from the battery or with the alternator (and obviously engine) running?
The reason I ask is that the current will drop a little at 13.5V which is their working voltage. My HID's won't even fire up sometimes
without the engine running due to my tiny gel battery.
Raz
matt_gsxr
posted on 26/5/10 at 10:41 PM |
Fair comment.
This was not with the engine running, but was on a big (50Ah) battery. The voltage won't be far off 12V. Maybe these are non-linear, i.e. more
volts will result in much less current. So maybe at 13-14V I will get 35W. That would be a good result.
I'm a bit grumpy as I got rained on, and what I thought would be simple (i.e. mount ballast, or ballst as it is labelled on the devices),
connect up existing plug, enjoy the savings in current. Turned into a project. Don't get me wrong I like a good project, but if I knew it was
a project then I would have stripped down their loom and done it all properly (i.e. proper sleeving on the solenoid wires, correct length wires,
properly fused into fuse box rather than a trailing 30A fuse, etc etc).
I'm just a grumpy old man. I should be revelling in the 3Amps that I have already saved.
Matt
p.s. those brake/rear lights are good, thanks for that tip.
