Author: Subject: Fuel proof transparent plastic
matt_gsxr
posted on 24/5/10 at 09:30 AM Reply With Quote
Hi there,
Does anyone know which plastics are fuel proof and also transparent? Many of them craze when in contact with fuel.
I am putting on secondary injectors in the airbox, and I want to see what they are doing. Its not for the bling, but to avoid the bang.
I'd prefer not to use glass, as if it broke it would get sucked into the inlet, with unfavourable consequences.
Thanks,
Matt
posted on 24/5/10 at 09:39 AM Reply With Quote
If the worst comes to the worst you could use clear / optical epoxy (epoxy resins are generally fuel proof) and "cast" a nice little sheet of that to use as a window.
Only trouble will be finding out if it's definately fuel proof other than by trying it. I doubt the optical / casting epoxy manafactuers will have thought of anyone using it for this...
Mal
posted on 24/5/10 at 10:15 AM Reply With Quote
I did a search for 'chemical resistance of polycarbonate' and came up with this detailed information
http://www.gallinausa.com/pdfs/polycarb.chemical.resistance.pdf
You could repeat the exercise for other possible plastics.
Mal
iank
posted on 24/5/10 at 10:20 AM Reply With Quote
Here's a big chart of plastic vs chemical compatibility.
http://k-mac-plastics.net/chemical-large.htm
Anonymous
matt_gsxr
posted on 24/5/10 at 11:32 AM Reply With Quote
thanks chaps,
FEP Fluoropolymer film seems to be the closest that I can get. I'll order some and see what its like.
Most others are no good.
Matt
tony-devon
posted on 24/5/10 at 01:29 PM Reply With Quote
I got loads of clear cast acrylic here at work, will try it with some petrol if you want?
I clean the surface with cellulose thinners before I spray it, but no idea what constant immersion will do to it.
heavy is good, heavy is reliable, and if it breaks, hit them with it
matt_gsxr
posted on 24/5/10 at 01:38 PM Reply With Quote
Looking at the table "Acrylic PMMA" does seem to have a "G" for good against it.
I don't know why I didn't think of that first.
Loads of it hanging around here too.
dohhh, its this hot weather addling my brain.
Matt
tony-devon
posted on 24/5/10 at 02:45 PM Reply With Quote
LOL I have clear cast acrylic , think I got pretty much everything from 1mm-1.5mm, 3mm 5mm 6mm
gimme a shout if you get stuck
