Author: Subject: Making engine mounts out of the Escort cross member?
MarkD
posted on 21/5/04 at 01:17 PM Reply With Quote
Just about to make up my engine mounts.
Maybe it's the bodger in me, but I'm tempted to try to chop up the Escort engine cross member and re-use that rather than fabricating the mounts from scratch.
Has anyone else done this - if so did it work OK or will I be wasting my time?
Car sold - looked like this when I gave up:
http://www.a1goods.co.uk/locost/
www.partywares.co.uk
Buy Cheap GPS Garmin eTrex Receivers, Gameboy Advance gear & Magic Tricks at http://www.a1goods.co.uk/shop/ (Blatant Ad!)
Dave Ashurst
posted on 21/5/04 at 06:22 PM Reply With Quote
IMO It's easy enough to make your own and hence fit the engine nicely.
Also it might get in the way if you modify the sump to improve ground clearance. You might want to compensate for the reduced volume by deepening the front of the sump, except you can't; your cross member will be there.
derf
posted on 21/5/04 at 06:27 PM Reply With Quote
I tried to modify the existing engine mounts from my rx7 and use them, and did it without a problem. I wasnt happy with the final height of the engine, and decided to try and make a set of custom engine mounts. Took almost the same amount of time, and I was much happier with the way they look and the height of the engine.
Here is a photo of the almost complete mounts, after this photo I ground out some of the welds which I wasnt happy with, and re-welded them better.
engine mounts
engine mounts
[Edited on 21/5/04 by derf]
James
posted on 21/5/04 at 06:46 PM Reply With Quote
MarkD,
All you need is a couple of bits of 50x3mm box section and 4x 3mm plates with some holes in them.
Was one of the few bits that was easy and went well!
James
posted on 21/5/04 at 08:07 PM Reply With Quote
This was shiny new 45x3mm RHS found at scrapyard and 3mm plate. Put the engine where you want it and fill in the space with metal.
http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=left_mount.jpg
No rusty old stuff to clean up and hack about.
