<<  1    2  >>
Author: Subject: BEC reverse set up ??
neo2
posted on 13/6/10 at 05:00 PM Reply With Quote
Hi guys i'm looking into putting a reverse gear set up on my MK Gsxr using the starter motor setup and toothed gear on the propshaft, ive been onto MK and they do a kit for £350 inc vat supplied only plus fitting if required etc...
Now i was wondering basically whats involved in fitting this, so ive a few questions if anyone can help me please
Q1, mk stated its a modified starter motor that when cranked turns backwards instead of forward (can you just not mount starter other way round ??)
Q2, where is the starter mounted in relation to the car, (i'm struggling to see where it can fit at all space wise)
Q3, Has anyone got any fitting pictures of location and mounting and stuff they can email me please...
barnsey1971@aol.com
thanks for reading Rob
ali f27
posted on 13/6/10 at 05:04 PM Reply With Quote
Have seen starter supplied from mk been modified with axe not impressed
AndyW
posted on 13/6/10 at 05:14 PM Reply With Quote
Davegtst
posted on 13/6/10 at 07:18 PM Reply With Quote
The sprocket is fitted between the diff and propshaft with the starter mounted either on top or below the prop. Have a word with AB performance, i haven't seen one but he says he has a reduction gearbox fitted to the motor and they are cheaper than MK's.
[Edited on 13/6/10 by Davegtst]
40inches
posted on 13/6/10 at 08:07 PM Reply With Quote
barnsey1971@aol.com
Q1: It's a VAG starter, they run backwards as standard.
Q2 & Q3:Check here and here
neo2
posted on 13/6/10 at 09:23 PM Reply With Quote
40 inches,, where did you get the drive sprocket for the propshaft made or did you buy the whole kit...
rob
40inches
posted on 13/6/10 at 09:37 PM Reply With Quote
rob
HPC gears in Chesterfield linky thingy. Here's copy of order if you are using Sierra diff.
Where do you live?
[Edited on 13-6-10 by 40inches]
neo2
posted on 13/6/10 at 09:43 PM Reply With Quote
i'm up in durham just been looking at the pictures of yours and the you tube video,
What starter motor did you use ? vag but off what car etc...
then i assume you made the brackets to mount it etc..
what car is your fitted too please..
neo2
posted on 14/6/10 at 09:30 PM Reply With Quote
Been in touch with HPC and they can supply the gear like yours for the propshaft for £121 all in...
So i think i will order one of those, The VAG starter what model is it of golf/polo etc etc..
neo2
posted on 16/6/10 at 07:39 PM Reply With Quote
seems the mk4 golf starter is a common one
40inches
posted on 16/6/10 at 08:09 PM Reply With Quote
This is the one I used:
9T 1.1KW GR M8 N
LRT00177
Cross Ref:
0001121006
0001121007
020911023F
020911023T
You can get them new on the Bay for around £50-£100, they fit all these models, so are relatively easy to find;
AUDI A3 1.6 00-02
AUDI A3 1.6 98-00
AUDI A3 1.6 AT 98-01
AUDI A3 1.8 AT 98-03
AUDI A3 1.8 AT 98-01
AUDI A3 1.8 Turbo AT
AUDI A3 1.8 Turbo AT 00-03
AUDI A3 1.8 Turbo AT 98-00 9T
AUDI A3 1.8 Turbo AT 98- 9T
AUDI A3 1.8 Turbo AT 99-00 9T
AUDI A3 1.8 Turbo AT 98-03 9T
AUDI A3 1.8 Turbo Quattro AT 98-00
AUDI A3 1.9 TDI AT 00-03
SEAT Alhambra 1.8 Turbo AT 98-00
SEAT Alhambra 2.0 AC AT 98-00
SEAT Alhambra 2.0 AT 00-
SEAT Alhambra 2.0 AT 98-00
SEAT Cordoba 1.6 96-02
SEAT Cordoba 1.6 AC 96-02
SEAT Cordoba 1.8 96-02
SEAT Cordoba 1.8 AC 96-02
SEAT Cordoba 2.0i 95-96
SEAT Ibiza 1.6 99-02
SEAT Ibiza 1.6 00-02
SEAT Ibiza 1.6 99-00
SEAT Leon 1.4 99-00
SEAT Leon 1.4 16V 99-02
SEAT Leon 1.4 16V AC 99-02
SEAT Leon 1.4 AC 99-00
SEAT Leon 1.6 99-04
SEAT Leon 1.6 16V 00-02
SEAT Leon 1.6 16V AC 00-02
SEAT Leon 1.8 20V AT 99-03
SEAT Leon 1.8 Turbo 00-01
SEAT Leon 1.8 Turbo 00-04
SEAT Toledo 1.6 99-
SEAT Toledo 1.6 98-
SEAT Toledo 1.6 98-02
SEAT Toledo 1.6 16V 00-02
SEAT Toledo 1.6 16V AC 00-02
SEAT Toledo 1.8 20V AT 98-03
SKODA Octavia 1.6 98-02
SKODA Octavia 1.8 Turbo 98-04
SKODA Octavia 1.8 Turbo 4x4 AT 00-04
SKODA Octavia 1.8 Turbo AT 00-04
SKODA Octavia 2.0 AT 99-02
VW VOLKSWAGEN Bora 1.6 01-05
VW VOLKSWAGEN Bora 1.6 02-03
VW VOLKSWAGEN Bora 1.6 98-01
VW VOLKSWAGEN Bora 1.6 98-05
VW VOLKSWAGEN Bora 1.8 Turbo 00-05
VW VOLKSWAGEN Bora 2.0 AT 98-05
VW VOLKSWAGEN Golf III 2.0 95-97
VW VOLKSWAGEN Golf IV 1.4 00-01
VW VOLKSWAGEN Golf IV 1.4 97-
VW VOLKSWAGEN Golf IV 1.4 99-00
VW VOLKSWAGEN Golf IV 1.4 AC 00-01
VW VOLKSWAGEN Golf IV 1.4 AC 98-
VW VOLKSWAGEN Golf IV 1.4 AC 99-00
VW VOLKSWAGEN Golf IV 1.6 97-
VW VOLKSWAGEN Golf IV 1.8 AT 97-98
VW VOLKSWAGEN Golf IV 2.0 AT 98-05
VW VOLKSWAGEN New Beetle 1.6 99-00
VW VOLKSWAGEN New Beetle 1.6 AT 00-05
VW VOLKSWAGEN New Beetle 1.8 98-01
VW VOLKSWAGEN New Beetle 1.8 99-04
VW VOLKSWAGEN New Beetle 2.0 AT 98-05
VW VOLKSWAGEN New Beetle 2.0 AT 98-01
VW VOLKSWAGEN Polo 1.6 95-97
VW VOLKSWAGEN Polo 1.6 AC 95-99
VW VOLKSWAGEN Polo 1.6 AC 95-97
VW VOLKSWAGEN Sharan 1.8 Turbo AT 98-00
VW VOLKSWAGEN Sharan 2.0 AC AT 98-00
VW VOLKSWAGEN Sharan 2.0 AT 00-
VW VOLKSWAGEN Sharan 2.0 AT 98-00
neo2
posted on 17/6/10 at 06:25 PM Reply With Quote
top man mate scanning ebay tonight and local motor factors etc..
neo2
posted on 17/6/10 at 07:39 PM Reply With Quote
Last question 40inches
What way did you wire it in for a curcuit via relay etc etc do you have to press any switch first ie like a safety device etc..
40inches
posted on 17/6/10 at 09:17 PM Reply With Quote
I have 2 batteries, a bike battery and the smallest 330ca car battery I could find,this is in the passenger foot well, with a full ally bulkhead/footrest, a split charge relay takes care of charging.
The live feed from the car battery goes through a 150amp continuous mega fuse to the motor.
Another smaller live goes through a relay switched by a feed from the ignition switch, then through another relay switched by the neutral switch ( you still awake?) then through a small lever switch (that is, it will when I have made it) then on to the starter solenoid.
I am still toying with the idea of switching the solenoid with a switch on the clutch pedal, leaving both hands free and making an easy clutch to brake pedal movement as a go/stop system. I think it would be more natural that way
[Edited on 17-6-10 by 40inches]
neo2
posted on 7/7/10 at 08:31 PM Reply With Quote
Spur gear has arrived
Had to drill the 4 holes for the diff bolts but its defo nice quality manifacturing..
Couple of questions again though if you dont mind please..
Q1, did you have to space out inner trim panels any ?
Q2, Did you have to use longer propshaft securing bolts min will only be as far in as the back of the flange no threads poking through etc..
Q3, Did you put a support on the rear of the starter motor as well..
thanks Rob
40inches
posted on 8/7/10 at 01:03 PM Reply With Quote
thanks Rob
Q1, Yes, mark on panel the spur gear location, then tap out a bulge 25mm longer and wider to clear the gear (cut a slot in a piece of 18mm MDF to use as a former)
Q2, Yes, 30mm long Alan head from fleabay, about £5 each Got to be cheaper somewhere else!!!!
Q3, No, but possible.
neo2
posted on 8/7/10 at 07:52 PM Reply With Quote
Thank mate, you have been most helpful...
40inches
posted on 8/7/10 at 08:20 PM Reply With Quote
Not a problem
Davegtst
posted on 8/7/10 at 09:22 PM Reply With Quote
Neo2 do you have the mounts already on the chassis for the starter? Mine came with the mounts fitted for the MK reverse setup but £350 is a bit too much for me. Do MK use the same VW starters?
[Edited on 8/7/10 by Davegtst]
neo2
posted on 9/7/10 at 08:54 PM Reply With Quote
No mate mine was'nt there so i did the the same as 40inches in fact i copied his specs 100% hope they wernt copy righted lol...
Save a lot of work like if they are already there, aligning and setting up and welding has been a bit of a mission to be honest as my car is fully built up..
Brackets done and welded in now though..
40inches
posted on 9/7/10 at 09:56 PM Reply With Quote
Neo, when you fit the motor you need 6thou of back lash. I cut off a 3thou feeler gauge from a set, shaped it around one tooth on the spur gear, placed it on a gear tooth on the starter motor (you need to extend the gear and lock it in the extended position with a cable tie) then adjust it on the bracket until it is tight, turn the spur gear until the feeler drops out. Done
I should say that the pressure angle on the spur and motor gear are different, the VAG gear is none standard bar stewards but, because of the low running time in reverse I was advised by HRP that it wouldn't be worth having a spur made to match, £240, it will be a bit noisy that's all
[Edited on 9-7-10 by 40inches]
40inches
posted on 9/7/10 at 10:18 PM Reply With Quote
Davegtst, in my photo archive you will find a drawing of the VAG starter motor, check it against the brackets on your MK, I could make it fit
The starter and spur gear shouldn't cost more than £200
Davegtst
posted on 10/7/10 at 04:49 PM Reply With Quote
Thanks for all your help. I'll try and order a gear in the week. At worse all i'll have to do is grind of the MK mounts and get the other brackets made up and welded on.
Davegtst
posted on 13/7/10 at 11:52 AM Reply With Quote
I hope i've just ordered the right one. The gear, vat and carraige came to £161 !!!
40inches
posted on 13/7/10 at 04:15 PM Reply With Quote
'Fraid so, £120+p&p+vat makes your eyes water! I tried,but couldn't find anyone else who made them any cheaper.
If you had a lathe, the gear blank is around £60 I think.
<<  1    2  >>
