New Topic New Reply
Author: Subject: Tracking needs doing!
robcool
posted on 13/6/10 at 06:38 PM Reply With Quote
Hello people
Wondering if anyone can help me? I need to adjust the tracking of my locost 7 as I am getting wear on the inside of the tyre.
I am not shore what it is set too at the moment. Has anyone got any idea what will be the best setting?
Rob
myeates
posted on 13/6/10 at 06:44 PM Reply With Quote
i set mine to 0 degrees last year and seems fine. mine was doing the same with wearing the inside edge of the tire
robcool
posted on 13/6/10 at 06:48 PM Reply With Quote
yeh well that what i was thinking about setting it to.
thanx
austin man
posted on 13/6/10 at 06:54 PM Reply With Quote
I set mine up using a laser level marked an equal measure at the front and rear of the tyre held the level flat on the rim and aimed it at the line front and rear, then measure distance between the fron marks and the rear marks and adjust to suit.
Took it to be tracked and it was spot on
Dusty
posted on 13/6/10 at 07:35 PM Reply With Quote
Agree it's probably tracking but excessive negative camber can do this too.
posted on 13/6/10 at 07:41 PM Reply With Quote
Camber first then toe-in --- also check the tyre pressures aren't on the high side.
RazMan
posted on 13/6/10 at 10:49 PM Reply With Quote
Surely excessive side wear normally indicates that pressure is too soft doesn't it? High pressure wears the centre too quickly.
I would set the tracking with a fraction of toe in (0.5mm ish) This allows for any slack to be taken up and tends to make the steering less twitchy.
Raz
posted on 14/6/10 at 07:51 AM Reply With Quote
If the pressure is to high the tyre wall won't conform to the road so if the camber is wrong it will only run on one edge of the tyre.
Steel belted radials don't change shape as much with as pressure as old fashioned textile radials or xplys.
Most modern low profile steel belted radials the crown of the tyre is designed depressed when deflated and because the steel belt doesn't stretch much remains that way when under pressure. Or to put it another way the shape and outer diameter of the tyre tread dosen't change much with with changes in pressure.
[Edited on 14/6/10 by britishtrident]
New Topic New Reply
