Author: Subject: Duratec bolts and conectors
Micael
posted on 21/6/10 at 08:43 PM Reply With Quote
I'm looking for Duratec connectors.
1 triggerwheel sensor connector
4 injector connetors (Bosch EV6)
and
clutch cover bolts (6 small ones)
Micael Moose Åman
Petrolhead and all around nice guy
"Don't leave the duck there. It's totally irresponsible. Put it on the swing, it'll have much more fun." //Sleep Talkin Man Dec 23 2009
flak monkey
posted on 21/6/10 at 09:16 PM Reply With Quote
Hi Micael
I have a set of injector connectors.
You can just use cap heads for the clutch cover if you want to. I think they are M8 from memory.
Sera
http://www.motosera.com
Micael
posted on 22/6/10 at 07:23 AM Reply With Quote
You have U2u
Dosen't the clutch cover bolts need to be in high strength (10.9/12.9 or so)
Micael Moose Åman
flak monkey
posted on 22/6/10 at 07:47 AM Reply With Quote
They should be 10.9, but cap head will be 12.9 anyway
Sera
Micael
posted on 22/6/10 at 07:57 AM Reply With Quote
When you say cap head, do you mean this type?
I'm trying to translate it to swedish terminology.
http://img.alibaba.com/photo/268425014/hexagon_socket_head_cap_bolt.jpg
Micael Moose Åman
flak monkey
posted on 22/6/10 at 08:00 AM Reply With Quote
Yep they are the ones
Sera
big-vee-twin
posted on 22/6/10 at 08:10 AM Reply With Quote
You can get the trigger wheel sensor connectors off ebay £4.99 I think
clutch cover bolts are M8 x 16mm
[Edited on 22/6/10 by big-vee-twin]
http://www.triangleltd.com
Micael
posted on 22/6/10 at 08:48 AM Reply With Quote
Thanks guys
Micael Moose Åman
