Author: Subject: Hayabusa internals- what BHP before upgrade
bitsilly
Contributor
Posts 726
Registered 9/6/05
Member Is Offline
Photo Archive Go!
Building: Flexibility into my marriage, bless her!
posted on 2/7/10 at 04:32 PM Reply With Quote
Is there any concensus on what BHP a busa can take before internals (other than clutch springs) need to be upgraded.
I'm really talking turbo or supercharger rather than anything else.
phoenix70
posted on 2/7/10 at 05:36 PM Reply With Quote
Yes, what it's come out of the factory with
I know a guy who is well up on bikes and he is doing the works on his busa before putting the turbo on ( forged crank, rod, pistons) .. Also know a kitcar owner who put a turbo on his busa and guess what... it went pop. (spat a rod)
Paul TigerB6
posted on 2/7/10 at 05:47 PM Reply With Quote
I wouldnt try to turbo something as expensive as a Busa without a set of H-beam conrods and forged low compression pistons to be honest. There's more power but loads more torque also with the turbo conversions - even with low boost
bitsilly
Contributor
Posts 726
Registered 9/6/05
Member Is Offline
Photo Archive Go!
posted on 2/7/10 at 05:52 PM Reply With Quote
I ask because I am drooling after this:
http://www.pistonheads.com/SALES/1803603.htm
which has my dream engine, but I spoke to the builder and the internals are absolutly standard, and TTS apparantly told him they would be OK up to 300bhp.
Thing is, I would use it mostly for track days, current owner uses it only on the road.
Thoughts??
bitsilly
Contributor
Posts 726
Registered 9/6/05
Member Is Offline
Photo Archive Go!
posted on 2/7/10 at 05:53 PM Reply With Quote
Sorry, he did reduce the compression with a metal gasket.
franky
posted on 2/7/10 at 06:25 PM Reply With Quote
Tts do not have the greatest rep, holeshot do!
posted on 2/7/10 at 06:37 PM Reply With Quote
I know of a couple of Busa's running 250-ish bhp on standard internals without any problems.
It's Evolution Baby!
INDY BIRD
posted on 2/7/10 at 06:43 PM Reply With Quote
buy something already done like this all reliavle power 1000's spent i should know its mine,
tempted???????
http://www.pistonheads.com/sales/1837610.htmlink
bitsilly
Contributor
Posts 726
Registered 9/6/05
Member Is Offline
Photo Archive Go!
posted on 2/7/10 at 06:53 PM Reply With Quote
I will if you can price match!!
imp paul
posted on 2/7/10 at 08:37 PM Reply With Quote
make sure you buy the parts from some 1 like hole shot racing jack or Tim blakemoor racing or big cc/ ray debben if you go down the turbo road as some people will rip you off like this good luck with your engine build tim and jack are very very good chaps all the best paul Description
YOU KNOW WHO YOU ARE
[Edited on 2/7/10 by imp paul]
kjouk
posted on 5/7/10 at 07:59 PM Reply With Quote
Thoughts??
Holeshot recommend different setups for cars & bikes. The theory is that in a car you will be on boost much more than on a bike and hence need the uprated internals.
I would not underestimate the difference between street and track use, I can barely get mine above 50% throttle on street use but the track it is quite different.
dilley
posted on 5/7/10 at 10:33 PM Reply With Quote
Holeshot and good rep???? Not wiyh me!
bitsilly
Contributor
Posts 726
Registered 9/6/05
Member Is Offline
Photo Archive Go!
posted on 6/7/10 at 04:37 PM Reply With Quote
I missed out again, he sold it to a dealer. Will keep an eye out for it but I guess it will be a tad more!!
clutch_kick
posted on 6/7/10 at 08:50 PM Reply With Quote
Could I suggest that you use a de-compression plate instead of a thicker gasket. If you take the correct precaution with fueling and ignition, i don't think you'd have any trouble running about 7psi boost, which should see you over the 200 bhp marks easy. Should keep you happy until you set aside enough money to upgrade the engine internals, and go wild on the boost.
