Author: Subject: Ford Ka heater control valves
dnmalc
posted on 14/7/10 at 10:19 PM Reply With Quote
On these it appears that they are controlled by a solenoid which would mean they were either on or off. Is this correct or are they progressive depending on the applied voltage?
se7en
posted on 14/7/10 at 10:32 PM Reply With Quote
Yes. They are controlled by voltage. Common failure in Ka, Fiesta, etc. Available on the bay. Can be a bit awkward to replace.
Hope this helps
Tom
posted on 15/7/10 at 06:21 PM Reply With Quote
Watch out for the plastic hose connectors on these valves failing as well , the last 2 or 3 that I've replaced have just crumbled
