geoffxt
posted on 23/7/10 at 10:24 AM |
Crankshaft Pulley
I'm still looking for a 2litre pinton crankshaft pulley to fix my megajolt trigger wheel to. Diameter approx 115mm.
Surely someone has one spare????
Can if you wish swap for a brand new double pulley!
mcerd1
posted on 23/7/10 at 11:52 AM |
they come up on ebay every now and then....
I've got one, but its cracked
so I took some sizes, tweaked it a bit and got one of these made
[Edited on 23/7/2010 by mcerd1]
blakep82
posted on 23/7/10 at 02:08 PM |
flak monkey likes making pulleys (well, don't know if he likes making them... but he can make them)
maybe he could make one with a trigger wheel built in?
________________________
mcerd1
posted on 25/7/10 at 08:47 PM |
the trigger wheel needs to be made of steel/iron or it won't work
paulf
posted on 25/7/10 at 09:24 PM |
Hi Geoff could you use the one you have if machined to fit the trigger wheel ? if so then you could call over some time with it and im sure I could
machine it for you.
Paul
quote: Originally posted by geoffxt
geoffxt
posted on 26/7/10 at 09:08 AM |
Hi Paul,
Thats a very kind offer. Do you reckon that you can cut/turn off the front section of the double pulley it's a cast one?
paulf
posted on 26/7/10 at 09:45 AM |
Probably, I cant remember exactly what the pinto pulley is like but assume it is just a solid cast pulley with 2 vees ? have you got a trigger wheel
yet ? if so then as long as theres enough metal to turn down to leave a spigot for the wheel then it should be ok, the wheel will want a few screws
through it to retain it also.
Paul
Hi Paul,
geoffxt
posted on 26/7/10 at 12:45 PM |
The pulley is a solid one with two vee's and I believe that it should be possible to remove the front of the pulley on your lathe. There should
be enough of the pulley left to attach the trigger wheel (which I do have) onto the remaining part of the pulley. How you do it I need to work out.
I'll try this evening to send you a couple of pictures by email. Cheers mate!
mcerd1
posted on 26/7/10 at 12:55 PM |
^^^ sounds like the locost version of my one
