<<  1    2  >>
Author: Subject: Whats your 0-60 times ?
graememk
posted on 27/7/10 at 03:11 PM Reply With Quote
Ok what do you think the fastest 0-60 you can get in a 7 is ? I’ve seen so many figures quoted that I don’t believe, what do you get in yours?
I’ll start with mine
5.8 seconds 0-60 recorded on my gps phone app, 150(ish) bhp 1.8 turbo Indy
bi22le
posted on 27/7/10 at 03:43 PM Reply With Quote
i snapped a drive shaft last time i did a standing start so im not trying it again untill i get the half shafts reinforced. That happened about 36 before leaving for nurburgring! I would guess mid 5sec. 150 bhp 4age raw striker
Please read my ring story:
MakeEverything
posted on 27/7/10 at 03:44 PM Reply With Quote
Im hoping for a close 5. Mid engined renault 21 supercharged engine.
Kindest Regards,
Richard.
jase380
posted on 27/7/10 at 03:48 PM Reply With Quote
never timed it usually too busy holding on, but fooking quick... indy zx10r 146bhp at wheels. Might make it my first job of the day tomorrow to time it
loggyboy
posted on 27/7/10 at 03:49 PM Reply With Quote
Thats about as reliable as someone sitting next to you with a stopwatch!
IF you want a cheap way to test, get to TRAX show on 5th Sept and they will use top end test gear.
http://www.traxshows.co.uk/book_now.shtml
Doofus
Not sure cos my speedo got bust doing a 0-60
cloudy
posted on 27/7/10 at 03:52 PM Reply With Quote
Under 3 for the R4, depends on the road surface as to how much under...
James
www.warnercars.com
graememk
posted on 27/7/10 at 03:53 PM Reply With Quote
hence why i put how i tested it
[Edited on 27/7/10 by graememk]
hobzy
posted on 27/7/10 at 04:30 PM Reply With Quote
4.5 on a Race technology meter.
Not been able to get the power down like it since. Total fluke of warm tyres, freshly laid road and running on fumes Haven't got it under 4.8 since.
chris mason
posted on 27/7/10 at 04:33 PM Reply With Quote
Best I can prove is 0-91.78mph in 7.736 seconds, that was with the Indy2000
I reckon the 1600 sr2 should be good for an equivelant in about 15 seconds or so
mackei23b
posted on 27/7/10 at 04:37 PM Reply With Quote
0-60mph 4.1 Seconds (Official Westfield Figure), not sure what I've managed!
omega0684
posted on 27/7/10 at 04:39 PM Reply With Quote
i have heard that Duncan's Hayabusa Turbo can do it in just over 3 seconds.
Mr G
posted on 27/7/10 at 04:42 PM Reply With Quote
With the speed humps, bumps, camera's and traffic chicanes round here there's no chance of even getting upto 60 anymore!
gingerprince
posted on 27/7/10 at 05:14 PM Reply With Quote
That's not accurate. I did trax in 2002 in my FTO and got this: -
It told me my 0-60 was 7.1 seconds but didn't start counting time until I was doing about 7mph!
ReMan
posted on 27/7/10 at 05:22 PM Reply With Quote
I'm going for 4.6 with me at 16st 1/4 tank of fuel.
Measuerd automatically with my on board Veypor
twybrow
posted on 27/7/10 at 05:29 PM Reply With Quote
4.4s in my Daytona powered ST - that was running the SVA map. Now I have it tweaked I must have another go!
goaty
posted on 27/7/10 at 05:46 PM Reply With Quote
timed 4.6secs with 150bhp pinto, two light blokes in the car.
carpmart
posted on 27/7/10 at 06:15 PM Reply With Quote
James
Wow, that's one hell of a time, how have you measured it? How is the R4 geared?
I don't think I can achieve that time in my race car with slicks and it only weighs 326kgs (wet without my lardy ass in the seat!).
My car is (only) blade powered but with less mass than a car (even an R4 ) and two 7 inch slicks, 12T front sprocket and 36T rear, I doubt I do a sub 4 second 0-60!
I'm amazed by your minimum sub 3 second time! I think I would need 'the perfect storm' conditions to get near that time! What do you think you could do on a grippy drag strip with some sticky slicks? Got to be worth another chunk of time! do you think that would shave a second off or am I too optimistic? Theoretically you would probably be in the late 1's early 2's as your sub 3 at present!
Hats off to you!
Interesting thread this!
[Edited on 27/7/10 by carpmart]
'94 MX5 MK1, 1.8
F10 M5 - 600bhp Daily Hack
Mercedes A class - Son's Car
Paul (Notts)
posted on 27/7/10 at 06:27 PM Reply With Quote
4.9 sec on my data logger on the 3rd attemp. Then decided to give up as I was going to damage either the gearbox or rear diff.
that was on a slight uphill run.
Main problem was avoiding the rear whell spin, and not changing gear!
Paul
madteg
posted on 27/7/10 at 07:06 PM Reply With Quote
0 to 60
3.5 Checked on in car camera at bakstone heath.
graememk
posted on 27/7/10 at 09:10 PM Reply With Quote
looks like flak monkey has the fastest 7 here then at 2.8 seconds, that must hurt your face.
piston heads
procomp
posted on 28/7/10 at 10:49 AM Reply With Quote
Hi
Our LA Golds when setup right with the anti-squat do 0-60 in 2.7s and the 64Ft in 1.9s on list 1A tyres. That's as recorded by Gordon Hick in his welsh sprint championship car. Although anyone who saw the LA Gold on A048's at Brands hatch a few months ago will know that those figures where obliterated on that start.
The good old live axle and a bit of anti-squat.
Cheers Matt
Doofus
posted on 28/7/10 at 12:04 PM Reply With Quote
Originally posted by procomp
Hi
Cheers Matt
Yowser,
That's impressive.
Is that with a special box?
I timed a run once and spent nearly 1 second changing gear....
procomp
posted on 28/7/10 at 12:16 PM Reply With Quote
Hi
Not that special. Just using a Quaife type 9 or 4 speed cant think whats in what car. But usually running a 2.04 first gear. So 60 mph is in first gear depending of diff ratio.
Cheers Matt
a4gom
posted on 28/7/10 at 08:40 PM Reply With Quote
it's something everyone thinks about but whats the most accurate locost way of measuring it?
Think my best 64ft time with this engine is about 2.4 secs and that's on 3 year old tyres if i can master the wheel spin i recon i'll get 2 or 2.1 but i have no way of measuring the 0-60.
Perfect planning prevents pi$$ poor performance!
<<  1    2  >>
