Author: Subject: Zetec fuel system spec
Cheffy
posted on 31/7/10 at 08:09 PM Reply With Quote
I'm sure this must have been covered before but after several hours trawling the site I still haven't found a definitive answer, so....
I'm just about to order the parts for the fuel system for my Zetec build and want to check I've got it right.
It's a standard 2.0l phase 3 Zetec black top. I've got a fuel tank but it doesn't have an integral swirl pot so I'm going to run with a separate swirl pot fed by a low pressure pump.
My questions are,
1. Should I use a 1 or 2 litre swirl pot, and,
2. What pressure and flow rate LP pump should I use.
And finally, with regard to the LP pump, has anyone used one of these as opposed to a genuine Facet Red Top?
TIA,
Mart.
PS. Apologies if this has been covered previously.
Farts are like Rock'n'Roll. You love your own but you hate everybody else's. Lemmy, Motorhead.
big_wasa
posted on 31/7/10 at 08:14 PM Reply With Quote
1L should be plenty.
My lift pump is 120L/h and 2psi
[Edited on 1/8/10 by big_wasa]
Cheffy
posted on 3/8/10 at 11:39 AM Reply With Quote
Thanks Wasa,
Much appreciated.
Mart.
