Author: Subject: Reversing thingy
Ninehigh
posted on 2/8/10 at 03:05 PM Reply With Quote
Reversing thingy
I remember some WW2 Jeep-esque vehicle that could use all the forward gears as reverse ones at the flick of a switch or lever.
Hopefully someone else knows what I'm talking about, if it's a mechanism worth trying in a Bec?
posted on 2/8/10 at 03:12 PM Reply With Quote
That was an Italian invention wasn't it ?
Miks15
posted on 2/8/10 at 03:15 PM Reply With Quote
if you have a reverse box you can do that in a BEC.
adithorp
posted on 2/8/10 at 03:19 PM Reply With Quote
Think you're talking about an Austin Champ which had a RollsRoyce engine. Post war (just) I think. Lots of national service guys ended up on a charge for trying to see how fast they could go backwards.
http://en.wikipedia.org/wiki/Austin_Champ
The reverse boxes available from quaife, MNR, etc, act on the output just the same and give all gears in reverse.
adrian
http://jpsc.org.uk/forum/
Ninehigh
posted on 2/8/10 at 03:41 PM Reply With Quote
adrian
Yeah that sounds about right. Has anyone actually done it in a Bec or is it not locost enough?
matt_claydon
posted on 2/8/10 at 04:02 PM Reply With Quote
A 3.14 LSD in Sierra casing with built in reverse would sell like hot cakes.
There was a car (can't remember name) with a 2-stroke engine where you just stopped the engine and restarted it running backwards by turning the key the opposite way when you wanted to reverse. This could be done on a four-stroke with some clever variable cam trickery.
posted on 2/8/10 at 04:06 PM Reply With Quote
I believe that French engineers also had a hand in the design!
It's Evolution Baby!
mcerd1
posted on 2/8/10 at 04:51 PM Reply With Quote
I disn't think the quaife reverse boxes are strong enough to handle full speed backwards.....
I think there is a diff out there that does that already - but its a very long way from locost
MakeEverything
posted on 2/8/10 at 05:13 PM Reply With Quote
Really bad for the bearings though.
Kindest Regards,
Richard.
posted on 2/8/10 at 05:19 PM Reply With Quote
I thought it was a straightforward 1:1 arrangement...
mcerd1
posted on 2/8/10 at 05:29 PM Reply With Quote
its definatly strong enough forwards & 1:1
but backwards I'm not sure if its still a 1:1 and rememer seeing something about a max recomended speed / torque or something...
[edit]
found it dax sell them for the rush MC (for ~£900 ) with this little disclaimer:
The Reverse Gearbox is only suitable for engines up to 250bhp. Reverse gear must
only be used to manoeuvre the vehicle slowly. e.g. Parking.
[Edited on 2/8/2010 by mcerd1]
g.gilo
posted on 2/8/10 at 07:15 PM Reply With Quote
reversey thing
the device for making 2 strokes run backwards was called a siba dynastart,
it was a starter/dynamo/reverse all in one.
it worked by retarding the ignition to a point where the engine when given a kick backwards by the starter would run quite happily backwards. some old 2 stroke bikes with the ignition timing a bit retarded were known to run backwards when kickstarted, you only found out when letting the clutch out.
