Author: Subject: Is drive shaft metal weldable?
smart51
posted on 2/8/10 at 07:52 PM Reply With Quote
My donor's speedo was mechanically driven from the front wheel but as I'm not using a scooter front wheel I need to drive it from teh front wheel off a FWD car. I've taken the drive shafts apart and now have a pair of empty ends. One of them I've cut the "cup" off so it is a flat plate with a splined shaft and thread for the hub nut. This will hold the hub to the upright nicely. I'd like to do the same to the other side and weld a coupling on to it so that it takes the speedo pick up point. I have no idea what the drive shaft stub is made from. Is the metal likely to be a grade of steel I can weld to?
Wadders
posted on 2/8/10 at 08:43 PM Reply With Quote
in short.. Yes
madteg
posted on 2/8/10 at 08:55 PM Reply With Quote
You can weld to it, but it will weaken it slightly but should be ok.
I sleeved my sierra shafts and welded sleeves ok for 18 months but then snapped one on start line at santapod, it was the weakest link.
smart51
posted on 2/8/10 at 08:57 PM Reply With Quote
Its only driving the speedo so torque isn't going to be the problem. Its a plan with no draw backs then.
Madinventions
posted on 2/8/10 at 09:42 PM Reply With Quote
I think driveshafts are made from spmething like EN16T but not hugely knowledgable in that area...
I cut and sleeved my Ford Puma driveshafts using a sleeve made from a lump of EN16T (tough stuff!), TIG'd it all together, and it's survived a Snetterton trackday and several hundred miles so far, so it should be ok to drive a speedo for you!
Ed.
View my band website:
http://www.shadowlight.org.uk
