Author: Subject: Mileage Correction - 2003 R1 Clocks
spdpug98
posted on 12/8/10 at 01:43 PM Reply With Quote
Has anyone had their 2003 R1 clocks re-set, I have been meaning to get mine set to the correct mileage for a while
Well today after getting it booked in, I have had a wasted 90 mile round trip after they found out they couldn't do them as they either need a special connector OR need to remove the LCD screen complete (including all the soldered joints) which will probably break/damage it
So, has anyone actually had theirs done and if so who did you get to do them
My Blog: http://spdpug98.wordpress.com/
Johneturbo
posted on 12/8/10 at 02:06 PM Reply With Quote
i had mine done, i had to send them off thou to guy called kenny decode!
think i have his number somewhere or do a search
spdpug98
posted on 12/8/10 at 02:10 PM Reply With Quote
Where they 2003 clocks and how much did it cost (feel free to PM if you want)
Johneturbo
posted on 12/8/10 at 02:12 PM Reply With Quote
here's the thread http://www.locostbuilders.co.uk/viewthread.php?tid=82423
no mine are 05 clocks, should be the same to reprograme thou
spdpug98
posted on 12/8/10 at 02:15 PM Reply With Quote
Cheers, the bloke I saw today said he could re-programe them but the chip he needed to get to was under the LCD screen and that was his problem - will give the bloke you used a call and see what he says
spdpug98
posted on 12/8/10 at 02:23 PM Reply With Quote
Thanks - Spoken with Kenny 'decode' and will be sending them up to him
CRAIGR
Contributor
Posts 2751
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 12/8/10 at 02:25 PM Reply With Quote
Did he give you a price ??
spdpug98
posted on 12/8/10 at 02:36 PM Reply With Quote
Yes........a lot cheaper than the companies down on the South Coast (I'll PM you - just incase he doesn't want it all over a forum)
Red16
posted on 12/8/10 at 06:13 PM Reply With Quote
where is this kenny decode based?
spdpug98
posted on 12/8/10 at 06:17 PM Reply With Quote
Manchester
adithorp
posted on 12/8/10 at 08:24 PM Reply With Quote
Kenny- decode did mine on 06R1. He does loads of radio decodes for me at work and I think I might have originally given john his number.
adrian
http://jpsc.org.uk/forum/
spdpug98
posted on 14/9/10 at 11:01 AM Reply With Quote
I know a few of you wanted an update on how the mileage correction went with Kenny Decode, all I can say is 'top service from a top bloke'
He did the clocks the same day as he got them and sent them straight back, arrived the next day
TQ_uk
posted on 15/9/10 at 04:31 PM Reply With Quote
Alternatively can you use a Speedohealer?
spdpug98
posted on 15/9/10 at 04:42 PM Reply With Quote
I have a speedohealer but they don't change the mileage readout on the clocks, just the speed registered/indicated
[Edited on 15/9/10 by spdpug98]
