Author: Subject: Crossflow to Sierra Diff Prop Shaft
nnrouty
posted on 12/8/10 at 03:51 PM Reply With Quote
Hi
Can anyone tell me where i can find a propshaft that will connect my 4 speed crossflow box to my sierra rear diff
mcerd1
posted on 12/8/10 at 03:53 PM Reply With Quote
what length do you need ?
nnrouty
posted on 12/8/10 at 03:58 PM Reply With Quote
Any size as long as the gear stick lands in a suitable position. I'm planning to fit my sierra diff, connect the prop to it and use the length of the prop shaft to determine the location of the gearbox and engine?
Marcus
posted on 12/8/10 at 05:49 PM Reply With Quote
Not a particularly good idea M8. The Sierra prop is way too long. The gearlever will be in the engine compartment!! (if it's a book ish chassis). Better to mount engine and box where you want and get a prop made up. You may still need a gearlever extension made up to get it in the right place.
Marcus
Because kits are for girls!!
DavidM
posted on 12/8/10 at 07:26 PM Reply With Quote
If youare intending to do any long drives in the car, fitting a Type 9 five speed would be worth consideration.
Proportion is Everything
nnrouty
posted on 12/8/10 at 11:34 PM Reply With Quote
i had thought about a type 9. Was hoping that mabe some body would make a prop shaft that would br suitable that i could buy off the shelf.
I am using a 1300 crossflow, if i was to use a type 9 would i get a reasonable amout of power from this setup?
blakep82
posted on 13/8/10 at 12:06 AM Reply With Quote
i've got 2. one is 10cm long, the other 3m long. any good? lol
nah, really don't build your car around the length of prop shaft you can find. most standard ford props will be far too long!
you will find someone on here, at some point, who happens to be selling one a decent length for your set up, but i'd recommend building your car, and placing the engine, and diff, and getting a type 9 for road use (it won't give you more power, but a more barable engine speed on motorway cruising) and approaching one of the prop manufacturers like Dunning and Fairbank, or Bailey Morris (i can't remember which i used unfortunately, but they were were good! i think it was D&F... i had it made to my specificacton within a week from order to delivery i think. was about £120 inc vat and delivery with brand new UJ bearings, and yokes? even specified the tube diameter i wanted.
do it that way!
here's mine
mines a bit long than you'd need, but my car is slightly different
[Edited on 13/8/10 by blakep82]
________________________
nnrouty
posted on 13/8/10 at 06:42 AM Reply With Quote
Thanks for the tip.
Soo, next question. Once i have placed the engine/box and the diff. Where do i measure from to find what length prop i need?
mcerd1
posted on 13/8/10 at 07:46 AM Reply With Quote
I think alot of cars use 900mm long shafts, but my dax one is about half that
James
posted on 13/8/10 at 08:05 AM Reply With Quote
Originally posted by nnrouty
Thanks for the tip.
Your prop manufacturer will tell you where to measure from.
blakep82
posted on 13/8/10 at 10:12 AM Reply With Quote
Thanks for the tip.
yep, i sent this off to a few of them
http://www.baileymorris.co.uk/pdf/kit_car_single_piece_shaft.pdf
you're best to measure from the diff flange to the the oils seal in the back of the gear box. they work out how much of the yoke goes in the box
Nash
posted on 13/8/10 at 06:44 PM Reply With Quote
This is exactly my current setup. I have a 1300GT x-flow with a trick cam, oversize bores etc. about 90BHP I'm told? I run a 5 speed type 9 box and its a good marriage. 5th is ideal for the motorway but do expect to have to work the box to get the best out of the car. Its half the fun after all.
............Neil
Build It, Buy It, Drive It:
Southern Kit Car Club
ritchunt
posted on 15/8/10 at 06:47 PM Reply With Quote
ive got one in the garage which i removed from my car when i fitted my redtop, the car was running a 1300 gt with 4 sd box if its any good to you?
