Author: Subject: Ford Puma cambelt help......
pewe
posted on 18/8/10 at 09:13 PM Reply With Quote
Still soldiering on replacing cam-belt on No1 son's newly acquired Puma (3 days and counting). Latest problem is trying to undo the crankshaft pulley nut.
Have fabricated a pulley locking tool but even that combined with third gear and stamping on the brakes and applying a breaker bar on the 19mm nut still hasn't resulted in the mother undoing.
Is there something we've missed or is it just a case of a bigger lever e.g. scaffold pole on the end of the breaker bar?
Any advice/help appreciated.
Cheers, Pewe
RichardK
posted on 18/8/10 at 09:23 PM Reply With Quote
I dunno, but could it be a left handed thread?
Just a thought
Rich
Gallery updated 11/01/2011
UncleFista
posted on 18/8/10 at 09:28 PM Reply With Quote
Long bar on it and hit the starter ?
Usually works like a charm (assuming it's not in bits)
Tony Bond / UncleFista
huskychaser
posted on 18/8/10 at 09:46 PM Reply With Quote
Timing belt
These are tightened to recomended torque, there is no key holding the lower sprocket, i use a Snap on 18v gun / wrench, or an air gun, but all must be set up correctly before un doing crank nut. Dave. ps un does the normal way.
[Edited on 18/8/10 by huskychaser]
beaver34
posted on 18/8/10 at 09:48 PM Reply With Quote
very tight, make sure you tighten it back up right with a new bolts as they like to unwind!
also i presume its the 1.7 be carefull with the vct if so, ive seen alot of bent valves by not doing it correctly
bmseven
posted on 19/8/10 at 10:13 AM Reply With Quote
As above VERY IMPORTANT to make sure all the timing marks are alignedTDC etc before undoing as it has no key way it's just done up FT.
Air gun gets em off for me
BMW 7 Resource
Bures Pit anyone?
adithorp
posted on 19/8/10 at 12:47 PM Reply With Quote
DO NOT DO THIS....
There's no key on the shaft for the timing belt sprocket and so you'll bend the valves if done that way.
Usually requires an impact wrench.
adrian
http://jpsc.org.uk/forum/
Mark Allanson
posted on 19/8/10 at 08:58 PM Reply With Quote
SIMPLE SOLUTION
Get a stanley knife, cut the existing belt down the middle so it is only 13mm thick, cut away the outer half. Slide on the new belt so it is half on the pulleys, cut away the remaining old belt, slide on the new belt so it is fully on the pulleys, refit the covers and go down the pub.
pewe
posted on 19/8/10 at 09:46 PM Reply With Quote
Thanks for the suggestions guys.
Looking at fabricating a half-moon insert (cut piece of scaffold tube) with a long bar to stop the pulley rotating.
Then it's out with the breaker bar, impact socket and the rest of the scaffold tube to lever the breaker bar.
Just hope it works!
Cheers, Pewe
Mark ^^ nice idea but Henry puts the cambelt pulley behind a very neat shroud on the crankshaft so it can't be slid off without removing the auxbelt pulley in front of it!
Mark Allanson
posted on 19/8/10 at 10:02 PM Reply With Quote
Bummer!
pewe
posted on 20/8/10 at 06:56 PM Reply With Quote
Success - made up a pulley holding tool by cutting some sections out of a scaffold pipe, welding them onto a piece of thick wall ss tubing offset so the sections fit inside two of the pulley webs but there's still access to the nut, end of tube onto the lower wishbone with a block of wood underneath it to cushion it, clamp the holding tool to the pulley with a small G clamp.
19mm impact socket with two extensions supported by axle stand, block of wood to cushion and taped to the stand so socket's positively located, breaker bar with extra scaffold pole leverage - what was all the fuss about?
Thanks for the help guys - just what I needed when I was about to give up.
Cheers, Pewe
PS anyone want their Puma cambelt changed?
bmseven
posted on 23/8/10 at 02:42 AM Reply With Quote
Originally posted by Mark Allanson
SIMPLE SOLUTION
But you still need to get the bottom pulley off in order to remove the cover
Glad you got it sorted its only a half hour job once you figure out how to get it apart
[Edited on 23/8/10 by bmseven]
BMW 7 Resource
Bures Pit anyone?
pewe
posted on 31/8/10 at 05:07 PM Reply With Quote
Final, final post on this in case anyone else is doing theirs.
1) Check cam timing at least twice before deciding it's correct - that means turning the crankshaft gently with a 19mm spanner. As a guide No1 ex & inlet cams should be pointing inwards at 1 o'clock and 11 o'clock respectively at TDC. Timing tools (cam and crankshaft locking tools from fleabay c.£16) a must.
2) Ensure camcover gasket is firmly stuck to the inside of the cover (Wellseal is great for this) before dropping the cover onto the cambox and/or use an OE one from Henry. The cheappo version from Eurocarparts is fractionally too small (seemed to fit OK until we ran the engine only to discover it had been nipped right at the back allowing oil to wee out!). Otherwise now 100% sorted (famous last words).
Took it for a blat on Sunday - what a cracking little car for not much money!
Cheers, Pewe
bigfoot4616
posted on 31/8/10 at 05:11 PM Reply With Quote
i chickened out and sent the wifes into a garage for the belt change.
your right, they are good fun little cars to chuck about the twisty stuff. just lack a bit in a straight line
