Author: Subject: Which sierra column shroud do I need?
Jasongray5
posted on 19/8/10 at 12:29 PM Reply With Quote
Afternoon Chaps!
My donor was a G reg 2.0i DOHC Sierra Giha, The top bit of the column shroud was missing? I have bought 2, one adjustable, one not, and neither fit? the place where they screw together is too narrow and catches on the "rippely" bit of the column?
Does anyone know if one out of a cosworth is what im after???
Cheers Guys, Jas
How hard can it be?
http://www.flickr.com/photos/33261515@N03/sets/72157611049241239/
snapper
posted on 19/8/10 at 01:21 PM Reply With Quote
I think they are pretty much the same fittings on all of them, square hazard switch is the older shroud used on non adjustable columns.
Round hazard switch should fit any column.
I had to cut the back of the adjustable top cover of the shroud to get mine to fit
I eat to survive
I drink to forget
Jasongray5
posted on 19/8/10 at 02:13 PM Reply With Quote
The 2 that I have dont even fit over actual column. The column is too fat for them. Howerver, the bottom half of the shroud that i removed from my donor does?
How hard can it be?
