Author: Subject: best way to wire fuel pump..?
robbydee
posted on 3/6/04 at 04:43 PM Reply With Quote
Just bought the facet silver top fuel pump just wondered which is the best way of wiring? can i use the red wire going to the lumenition >? or should i go back to the ignition ? if so which one on the standard sierra ignition switch ? wats the yellow?
gjn200
posted on 3/6/04 at 05:33 PM Reply With Quote
Do you mean direct? Hope not!
I would use a seperate fused supply switched by a relay connected to the ignition (out) terminal of the ignition switch.
<- Me!
robbydee
posted on 3/6/04 at 09:38 PM Reply With Quote
what sort of relay? and where from?
posted on 4/6/04 at 10:24 AM Reply With Quote
Robby,
You would be well advised to get a manual from Sierra (assuming that's yor donor) and copying the wiring from that. No disrespect, but it sounds likely you are pretty green with regards to wiring. Using the original wiring schematic and the manufacturer's wiring you can't 'really' go that wrong. Petrol/electrics don't go together too well
Just my [img][/img]
mad4x4
posted on 8/6/04 at 03:35 PM Reply With Quote
Is is advisable to have a "Switch" on the line to the fuel pump.?
Scot's do it better in Kilts.
givemethebighammer
posted on 8/6/04 at 05:13 PM Reply With Quote
Done mine like this
http://www.locostbuilders.co.uk/viewthread.php?tid=13338
As a safety feature no oil pressure = no fuel pumping into carbs, but there is a bypass switch to overide this.
