New Topic New Reply
Author: Subject: Strut Mushrooms don`t fit - Sierra/Granada?
StuartBJ
posted on 22/8/10 at 06:43 PM Reply With Quote
Hi Guys,
Ran into another problem today.....
My mushrooms don`t fit (slightly loose) even when the pinch bolt is fully done up..... now I`m sure this is my own doing as I`m using Granada Front hubs (as it works with my Merc alloys and discs etc)....
Can you get larger versions for the Grandada hub?.....it never crossed my mind that they would be different....or should I trim the strut pinch slot so it can get a grip.... this seems the quickest solution as its not far off?
[Edited on 22/8/10 by StuartBJ]
big_wasa
posted on 22/8/10 at 06:45 PM Reply With Quote
You will snap the casting if you just do them upo a bit more.
You need bigger ones.
StuartBJ
posted on 22/8/10 at 06:48 PM Reply With Quote
That did cross my mind, I can get them made by a friendly turner I know, or maybe sleeve the orginals..... do you know if you can buy bigger off the shelf?
snapper
posted on 22/8/10 at 06:51 PM Reply With Quote
That's an interesting problem, shaving the pinch bolt face is a solution as long as it is just a millimetre or 3 and not lots. Another solution would be to find some steel tube to go over the mushroom, enough to take up the slack
Weld it on or bolt through upright spacer and mushroom
[Edited on 22/8/10 by snapper]
I eat to survive
I drink to forget
StevieB
posted on 22/8/10 at 06:58 PM Reply With Quote
I say play safe and have some machined.
I'm sure a good solution can be engineered using the parts you have, but the only way you'll find the fault will inevitably be on the road (and if you're lucky, you'll be going slow and not flat out round a corner at the time).
Doubly so when you consider the engine you're packing and the power/torque it puts out
[Edited on 22/8/10 by StevieB]
StuartBJ
posted on 22/8/10 at 07:00 PM Reply With Quote
Lots of possible solutions each with their pros and cons.... sleeving sounds a quick and safe solution (assuming a suitable sleeve can be found).......I think I need a measure up
Talon Motorsport
posted on 22/8/10 at 07:04 PM Reply With Quote
I'd go with making new bigger mushrooms personaly, safer than the steel shim working its way out of the clamp.
StuartBJ
posted on 22/8/10 at 07:05 PM Reply With Quote
Point well made Stevie
StuartBJ
posted on 22/8/10 at 07:10 PM Reply With Quote
..... I think it would always be in the back of my mind if I didnt get a dedicated part made.
stevebubs
posted on 22/8/10 at 07:15 PM Reply With Quote
can you get a part from a cobra supplier? Don't some of those use Granada hubs?
interestedparty
posted on 22/8/10 at 07:21 PM Reply With Quote
Talon Motorsport (finds him on the Haynes Forum) make their own mushrooms for Sierras, with the offset, so if you had the dimensions you could contact them and I'm sure they would knock you up a couple with larger OD (as long as the material they start with is big enough)
http://stores.shop.ebay.co.uk/Talon-motorsport__W0QQ_armrsZ1
[Edited on 22/8/10 by interestedparty]
StuartBJ
posted on 22/8/10 at 07:29 PM Reply With Quote
Result.....Thanks
Liam
posted on 22/8/10 at 07:45 PM Reply With Quote
I had the same problem with my 4x4 front uprights. MK made me a custom pair of mushrooms, if I recall, for the same price as standard ones.
StevieB
posted on 22/8/10 at 08:24 PM Reply With Quote
And don't forget that if you haven't already tried to fettle the mushrooms you have, someone on here might want them and you'll recoup some of the money back.
jollygreengiant
posted on 22/8/10 at 10:57 PM Reply With Quote
I had a similar quandary when I built up my Luego. I was going to use all the Granada running gear, then I found that the mushrooms didn't fit. I thought about shimming etc, but also considered that the Granada upright is also TALLER than the Sierra upright and fitting this on the wishbones designed for Sierra uprights would also affect the geometry. So I ellected to go for the Sierra uprights and thought about fitting the Granada spindles in the Sierra hubs. That was also a NO-GO option so I had to use the Sierra hubs and spindles, but this would mean that I had 4 stud fronts with 5 stud rears. Didn't fancy that so looked at the rears and found that it was a simple operation to swap the Granada 5 stud rear drive flanges for the later Granada/Scorpio 4 stud drive flanges (these have the same PCD as Sierra) with no further complications. So if Henry Ford thought it was ok to run a large car on 4 stud wheels, who am I to argue.
Hope this helps and makes sense.
[Edited on 22/8/10 by jollygreengiant]
StuartBJ
posted on 23/8/10 at 10:00 AM Reply With Quote
Ahhhh I see, at least I`m not alone on this then.....I`m surprised that an off the shelf solution doesn`t exist, esp for the 4x4 hubs, which I suspect are the same as the granada.
I`m not fussed regarding number of studs (4 or 5), the reason I use Granada 5 stud is that it all matches up with my merc gear 5 x 112 pcd.
I`ve made contact with Talon Motorsport who are happy to help turn some bigger mushrooms for me
StuartBJ
posted on 13/10/10 at 07:46 PM Reply With Quote
Another hurdle down.....and the final result.......
mushroom1
mushroom1
mushroom2
mushroom2
[Edited on 13/10/10 by StuartBJ]
mcerd1
posted on 14/10/10 at 07:21 AM Reply With Quote
Originally posted by jollygreengiant
…...So I ellected to go for the Sierra uprights and thought about fitting the Granada spindles in the Sierra hubs. That was also a NO-GO option so I had to use the Sierra hubs and spindles....
Not if you know how
The granada hubs [spindles] just need turnned down to fit in the sierra bearings & seals - cost £10 the pair
Originally posted by jollygreengiantbut this would mean that I had 4 stud fronts with 5 stud rears. Didn't fancy that so looked at the rears and found that it was a simple operation to swap the Granada 5 stud rear drive flanges for the later Granada/Scorpio 4 stud drive flanges (these have the same PCD as Sierra) with no further complications.
With the exeption of the number of wheel studs (4x108 or 5x112) the rear hubs for disc brakes are the same on all the 4x4's, XR4's, Granada's, Scorpio's and other Sierra's with ABS (but not the cossie's) - so these just need mixed and matched to get what you need
Are you going to add anything to secure the mushroom ?
(I beleve some people have been drilling and tapping the upright to fit a small bolt to keep the IVA man happy :?, my dax ones have a flange/tang welded on them that the pinch bolt goes through the same way it does on the sierra's shock)
[Edited on 14/10/2010 by mcerd1]
Andy_B
posted on 15/10/10 at 06:25 PM Reply With Quote
Hi been reading this post with intrest ...i am intending in using my granada uprights too ...did you manage the steering column and rack from the granada ??
StuartBJ
posted on 15/10/10 at 07:50 PM Reply With Quote
No I'm using an escort rack. I wouldn't imagine there wouldn't be much (if any) difference in length to that of the Sierra rack, that would stop you from using a granny rack..... If you have one try it on, if not just buy a Sierra one.... Assuming you kit uses sierras as donors ?
Andy_B
posted on 15/10/10 at 08:17 PM Reply With Quote
Could be a while yet mate only picked up the donor today ...somebody posted i would not be able to use the uprights due to geometry issues or the column and rack either ...was starting to wonder....at least i have a useable engine and box...cheers for reply !!
New Topic New Reply
