Author: Subject: Zetec turbo clutch
v8james
posted on 25/8/10 at 10:56 AM Reply With Quote
Zetec turbo clutch
I am running a silver top 2.0L Zetec with a td04 turbo, 1800 flywheel and clutch.
I have only done 200 miles and the clutch has started to slip.
Can anyone suggest an upgrade?
andkilde
posted on 25/8/10 at 11:56 AM Reply With Quote
I saw some folks talking about redrilling the Zetec flywheel to accept a Pinto cover in another thread. Might give you a few more options.
t
locoR1
posted on 25/8/10 at 12:27 PM Reply With Quote
That would be madteg on here, Kev's running a turbo zetec he had lots of problems with clutch slip. would be worth a u2u if he doesnt post later.
Check out my CB500T Cafe Racer build diary
madteg
posted on 25/8/10 at 05:10 PM Reply With Quote
Had allsorts of problems with clutch in the end a had a 1600 zetec flywheel drilled and pegged to axcept a pinto clutch and then i fitted a paddle clutch. Problem solved.
v8james
posted on 26/8/10 at 11:27 AM Reply With Quote
Thanks for the info. Did you use the 1600 flywheel because it is lighter?
