Author: Subject: Pinto/Zetec starter motor spacer
RichardK
posted on 25/8/10 at 07:24 PM Reply With Quote
To use a pinto starter motor on a zetec it needs to spaced from the bellhousing by 14mm, I have made a spacer and thought I'd share the drawing with you that I used.
Rich
Gallery updated 11/01/2011
robocog
posted on 25/8/10 at 08:37 PM Reply With Quote
I ended up turning some thickish "tube" type spacers and just tack welded some thin steel sheet to stop the crud getting in (and to aid fitting them without playing chase the spacer!)
Mine was the most minimal affort solution I could think of at the time ..but I'm liking the way you did it !
lotusmadandy
posted on 26/8/10 at 08:19 AM Reply With Quote
Nice Rich,
That looks better than my effort.I believe
a bit of ripping off is in order
