couch22k
posted on 25/8/10 at 07:59 PM |
VIN Number again.
Right after getting a VIN number from the nice people at th DVLA I thought i was all sorted. But when I came to stamp the chassis today, which i
thought would be easy, the stamps just bounced when i hit them and hardly made a mark in the metal.
I made a plate by stamping some thin steel with a solid bit underneath it and its come out spot on.
I just wanted to know if its alright to rivet it to the chassis or if not can i weld it to get it through IVA.
Also made a VIN plate up with Make, Model Axle weights ect which im planning on riveting to bulk head, if its ok there, or does this need riveting to
chassis to.
Rang VOSA today but nobody there to give me a answer.
Any suggestion would help.
Steven
big_wasa
posted on 25/8/10 at 08:03 PM |
Nottingham iva guy told me monday that he was more than happy with a welded plate and it could be stiched on and didnt need to be welded all the way
around.
He also said the second one could be a printed sticker.
couch22k
posted on 25/8/10 at 08:10 PM |
around.
Sounds good, booking mine into Nottingham.
gavin174
if you want to stamp the chassis.
jack the car up and put it on axle stands.
the suspension and tyres take out all your effort..
i found it easier to stamp a bit of 20mm bar and then weld it to the chassis..
doesnt matter if you make a mistake either.
adithorp
posted on 25/8/10 at 09:52 PM |
Trying to stamp the chassis tubes can dent them. Stamp a steel strip and weld it on (rivets wont do). It has to be part of the chassis which it is
once welded.
adrian
http://jpsc.org.uk/forum/
couch22k
posted on 26/8/10 at 11:41 AM |
Thanks all. Nice easy job for today then
[Edited on 26/8/10 by couch22k]
