MikeR
posted on 26/8/10 at 02:50 PM |
Microsquirt - what doesn't it do compared to other ecus?
I've just found that you can get a microsquirt (which is a slightly cut down version of the megasquirt) for 300 pounds in the uk.
So this has me wondering - what doesn't it do compared to a) megasquirt and b) omex 600.
(i appreciate the omex is a heck of a lot dearer but as there has just been a bulk buy i'm hoping people are up to speed on its features
therefore what the microsquirt is missing and I'd be compromising on).
I've already got a wideband (assuming it works, its one of the 14point7 ones from the bulk buy last year).
Engine will initially be a crossflow and then later on a zetec.
[Edited on 26/8/10 by MikeR]
myeates
posted on 26/8/10 at 03:06 PM |
cant help on what it doesn't do in comparison to others but i have been running one on my car for nearly a year and its been fine sitting tuning
itself with the wideband most of the time, my car is a crossflow and runs way better than it ever did on a carb
Mark
ruudbeckers
posted on 26/8/10 at 03:08 PM |
I believe the microsquirt does not have a map sensor.
MikeR
posted on 26/8/10 at 03:20 PM |
From my limited reading you can (for extra pennies) add a map sensor to the wiring loom and it will use it.
snapper
posted on 26/8/10 at 04:09 PM |
Lots of infoon EFI Extra web site
I eat to survive
I drink to forget
MikeR
posted on 26/8/10 at 04:42 PM |
I must be looking in the wrong place as i can't find any reference to microsquirt on extra efi - just reference to the normal versions of
megasquirt.
40inches
posted on 26/8/10 at 05:34 PM |
Info on MegaSquirt about 1/4 way down page and MicroSquirt forum
here
daxtojeiro
posted on 27/8/10 at 01:27 PM |
megasquirt.
Hi, this is directly off my site, hope it helps:
First a little history (sorry, I know it's boring but it does help with how we got here).
Bruce and Al (thats B+G, the 2 people who own MegaSquirt) produced the first real MegaSquirt around 2002 time. This is known as MS1 and this
microprocessor could be run on a PCB called the V2.2, also produced by B+G.
Then James and I got involved and we came up with the MS1-Extra code, this took us a few years to develop up to the current and last code which is
version 029y4. This could be run on an MS1 microprocessor with a V2.2 board, then in 2005 the V3.0 board was produced, which again could run the
MS1-Extra code on it with the MS1 microprocessor. The MS1 can also be run on the V3.57 board, but more on the boards later. The big advantage for
using the MS1-Extra code over the original B+G code for MS1, was that it gave you 12x12 tuning tables for fuel, 8x8 for ignition and up to 6 spark
outputs (so anything up to a V12 could be controlled with ignition and fuel!!) where as the standard MS1 with the B+G code had an 8x8 fuel table and
no ignition. Another major step forward was wheel decoding, this means it can read standard pulses from lots of different engines, e.g. the Ford 36-1,
Bosch 60-2, etc. The Extra code also gave you things like launch control, rev limiters, boost control, PWM idle control, knock control, etc, etc ,
etc! None of this was possible with the MS1 basic code, so if you go for an MS1 then it has to have the MS1-Extra code running it if you want your car
to work. This is easy to do and costs nothing. It is my opinion that you should ignore the other code and just put Extra in it from the start, this
way you should be running quicker. I've never sold an ECU that needed the original code in it, all have been sold with MS-Extra, all my Help
files are setup for MS-Extra and all my ECU's are loaded and configured ready for your engine with MS-Extra.
Anyhow, back to the history lesson. A few years later MS2 was brought out by Bruce and Al, basically this was a daughter board that replaced the MS1
processor on the V2.2, V3.0 or V3.57 board. This daughter board has CAN capability, a faster processor, more memory and the ability to drive a stepper
motor idle vavle. Despite this the MS1 processor using the MS1-Extra code was still the most popular ECU as it could run far more engines than MS2
could, mainly due to MS2 (B+G) only being able to control one (may have been two, I can't remember) spark output(s). So people still tended to
go for an MS1, with MS1-Extra code. The MS1-Extra code had now got as far as it could, (version 029y4), so I concentrated on writting the MS1-Extra
Manuals, making it easier for people to use and run the code, whilst James teamed up with Ken and started to put the Extra features from MS1-Extra
into the base MS2 code from B+G. This code is known as MS2-Extra and slowly it has become more popular. It has more features than MS1-Extra and can
decode a lot more standard crank/cam wheels. Again, it is my opinion that all MS2's should just start with the MS2-Extra code, as you will be up
and running quicker. Just like my MS1 ECU's, all my MS2 ECU's come with MS2-Extra loaded into them and all my Help pages are for the Extra
code.
Now the MS3 has been released we have another option to throw into the mix. The real difference with this is that Bruce and Al left it to the Extra
team to do the code from the start, so there will not be a B+G version then an Extra version. Again, it is a daughter board that plugs into the main
board, so its upgradeable from MS1 or MS2. This has an expansion board that can go with it, called an MS3X card, this has lots of built in outputs and
inputs ready to use on features like launch control, boost, etc, so they don't need building onto the main board like the MS1-Extra and
MS2-Extra ECUs have. For more on the MS3X see HERE.
So what about all the boards, V2.2, V3.0, V3.57, then there's MicroSquirt's, PnP and all sorts of other things:
V2.2 is really obsolete now, it can't do ignition control easily (EDIS is OK), it has no VR conditioner on it, so running 36-1 or 60-2, etc,
isn't possible without adding a board to it. These are fine for EDIS based setups where no inputs or outputs are needed for knock, boost, tacho,
etc. It also can't control low impedance injectors without another board being added to it and it doesn't have such a high noise immune
power circuit like the V3.0 board does. There is, however, a built in MAP sensor that can cope with up to 21psi as standard or can be upgraded to
38psi, but this i the same as a V3.0 board. I just wouldn't bother with them as you will soon out grow it and want more. Reselling them is also
hard as most people want more from an ECU than these can give, so prices do seem to be low for these.
V3.57: This is a copy of the V3.0 but using surface mounted components, but it is a nightmare to add things to as it has no area for soldering
components needed for items like launch control, tacho, knock, etc, unlike the V3.0. There is a built in MAP sensor that can cope with up to 21psi as
standard or can be upgraded to 38psi. The components are very small, so soldering wires onto them is also very tricky to say the least, so why bother,
when the V3.0 is such a good board and easily fixed if it all goes wrong! After all, the V3.57 is simply a copy of the V3.0 with some stuff
missing.
MicroSquirt's: These all run MS2 processors and it can't use an MS1 or an MS3 processor (so can run MS2-Extra code). Again they are
limited to what you can do to them, they do have 2 VR inputs, which is handy for cam/crank signals, but then they only have 2 spark outputs. So the
second input (cam input) can't really be used for sequential spark with only 2 drivers, as 2 coils is all it can fire without external ignitors,
meaning 4cy wasted is the best it can do. It also can't run low-impedance injectors, as it has no peak and hold circuit. The max injector
current is 5A per channel, so 4 x hi impedance injectors/bank is the limit. It has no Idle valve output in either PWM form or stepper motor form and
it can't be upgraded to an MS3. If you want to use any high powered outputs like tacho, idle, boost control, cooling fan, you'll need to
add boards to it, making it bigger. It also has no built in MAP sensor, so you can't run Speed Density without adding a MAP sensor externally,
which means you can only run Alpha_N.
The MicroSquirt is very small, a standard MS1 or MS2 ECU is 180x105x45mm, a MicroSquirt is approx 61x89x45mm, so it's my opinion that these are
best suited for motorbike's with up to 4 cylinder engines, where space is limited. It's intended us is for odd fire 2 or 4 cylinder
engines, e.g. Harley, Ducati, etc.
V3.0: It is my opinion that the V3.0 board is still the main board to use, it is easy to fix if it goes wrong (which is rare) it has a built in VR
conditioner so can be used with 36-1, 60-2, etc, it can easily be modified to run 1, 2, 3, 4, 5, 6, or more spark outputs. It can drive high or low
impedance injectors, it is compatable with MS1-Extra, MS2-Extra and MS3. It has an area for adding components for extra's like tacho, launch,
knock, etc and the MS-Extra manuals are written around it. There is a built in MAP sensor that can cope with up to 21psi as standard or can be
upgraded to 38psi. It's also the only board I've used since 2005 in my MS1 and MS2 ECU's.
Phil
matt_gsxr
posted on 27/8/10 at 07:39 PM |
chart here comparison chart link
The disadvantage of microsquirt is that it is sealed so you can't add functionality (like you can with the other MS boards).
The advantage of the microsquirt is that the packaging is better (than the DIY version), manufacture is better (than the DIY version), and it seems to
include all the functionality that you would need.
Matt
[Edited on 27/8/10 by matt_gsxr]
omega 24 v6
posted on 27/8/10 at 08:33 PM |
Hurrah Phil is back all our squirt problems will be resolved.
Seriously though welcome back Phil.
