Bitsablade
posted on 26/8/10 at 11:35 PM |
Blade-powered Locost with Trailer
Regrettably for sale, and only due to change in circumstances.
Fireblade-powered Stuart-Taylor Locost road-registered on Q-plate in August 2007
Currently has 11 months Tax and 7 months MOT
Specification is as follows:
Engine
1997 Honda Fireblade 919cc (Carb)
Lighly-tuned by isle-of-man TT race preparation mechanic (increased compression, kent cams, slotted cam-sprockets, valves re-faced and seats cut) less
than 400 miles ago
Full Gearbox rebuilt less than 400 miles ago
TTS Dynojet kit supplied, fitted and carbs balanced by AB Performance using the 750mc RGB jetting set-up.
AB Performance Air-box with K&N filter ducted to AB Performance NACA duct located in the nose cone
Custom-made shortened sump with stainless-steel baffle-plate
OEM Honda clutch plates with Heavy Duty Barnett springs
MK Engineering 4-1 Stainless steel manifold
Custom Chrome Racing Stainless steel silencer with removable bung for trackdays (98dB static)
Custom-made aluminium fuel tank with internal baffle-plate and swirl-pot (6-gallon capacity)
Early Fireblade self-regulating fuel pump manufactured by Mitsubishi Corp.
VW Polo Radiator with 12” fan and Revotec manually-adjustable fan-switch
All-aluminium cooling loop complete with silicon hoses sourced from AB Performance
MOCAL 11-row Air/oil cooler on sandwich-plate with braided hoses
Uprated “Superdream” regulator/rectifier
Stripped wiring loom (non-essentials removed)
Chassis & Drivetrain
Locost book-chassis with black powdercoat finish.
MK Engineering weld-in rollcage
Dunning & Fairbank TRT propshaft with centre bearing and sliding rear section
Ford Escort Mk2 RS 3.54 english axle with twin trailing arms and rose-jointed panhard rod
Suspension
Protech front shocks (adjustable for bump and rebound) with 225lb D.Faulkner springs
Avo rear shocks (adjustable for bump and rebound) with 150lb D.Faulkner springs
Quick-rack
Rose-jointed and fully adjustable front suspension utilising Ford Escort Mk2 uprights
Brakes
4pot Hi-Spec calipers with Mintex 1144 pads (front)
Rebuilt Ford Escort Mk2 RS 9” rear drums with Ferodo shoes (rear)
Hardlines direct to goodridge braided hoses
Wheels & tyres
6 x Ford Escort Mk2 RS Alloys (6J x 13”) 4.5KG each (4 powder-coated in anthracite)
4 x Toyo R888 GG (185x60x13)
2 x Part-worn Yokohama A048 M (185x60x13)
Bodywork and fittings
Light-weight aluminium side panels (Sikaflex bonded)
Fully flat-floored (large-head rivets and Sikaflex used to secure)
ETB DigiDash II with IR lap-timer and Beacon
Datatool Digi Gear indicator
Odyssey PC545 Battery
FIA Master switch
MK Engineering pedal-box
Racetech mirrors (centre and wing) with Racetech 260mm steering wheel on Racetech removable boss
Stuart-Taylor Paddle-shift via AB Performance cable
Double-skinned GRP seats on adjustable runners
Brand-new TRS 4-point harnesses
Carbon-fibre dash
Caterham CSR replica carbon-fibre reinforced cycle wings.
Acoustifoam noise-insulated nose cone and bonnet
MNR bonnet scoop
Savage Switch bank (Start, side-lights, dipped, main-beam, fog, horn, hazards)
Aluminium passenger footrest
Trailer
Custom-built using brand new components
Fully galvanised
Alko braked single axle rated to 1150KG
3mm high-density steel runners
3mm high-density steel removable ramps
Rear stays
14'7” Total length
7'1” Total width
Other
Flatshifter Pro (full-throttle clutchless upshifts/downshifts with engine blip)
Custom-made Mohair Tonneau cover with centre zip and push-the-dot fasteners.
Corner-weighted & geometry set-up by AB Performance (470 KG with 5 gallons of fuel)
Recently Dynoed at 142 BHP / 74ft/lb with graphs to support (equates to 306 BHP per tonne)
Comprehensive documentation including build photos and wiring-diagram
Spares package included
Please contact me on 07720548853 with any questions or for further information.
Located near Coventry.
Priced to sell as a complete package at £9750 ono
skippad
posted on 27/8/10 at 07:14 AM |
That is a nice car....
posted on 27/8/10 at 10:47 AM |
Is that you Pat...?
Shame to see you selling up I know you put a lot into that car.
Bitsablade
posted on 27/8/10 at 10:43 PM |
Thanks for the kind comment skippad...tempted?
Sorry nick, it isn't Pat but it is Pat's car - my dad and I bought it from him back in January 2008. I'm just hoping that everyone
who contributed to the build (and I know there are many from looking back through the threads that Pat created before buying it) feels our efforts in
developing it since then have done his justice.
Fantastic car and a very sad sale
