rich201283
posted on 1/9/10 at 07:28 AM |
How could i fit 98mm pcd alloys to 101.6mm pcd?
How could i fit 98mm pcd alloys to 101.6mm pcd.
I have some fiat x19 alloys laying about and would like to fit them to the viva hubs?
pekwah1
posted on 1/9/10 at 07:49 AM |
are they 4 stud?
should be able to find some adaptors somewhere, or even get a company to make them for you.
1. they won't be particularly cheap.
2. they'll increase the offset but at least 20mm.
Otherwise possibly find someone to redrill the alloys?
RazMan
posted on 1/9/10 at 08:00 AM |
Remember the hub bore size needs to be modified too or you will get wobbles.
Raz
pekwah1
posted on 1/9/10 at 08:07 AM |
forgot to add, if you are looking at pcd adaptors, there is such a thing as a 'wobble bolt' which effectively has the thread slightly
offset on it.
This would allow you a bit more leeway on the fitment, but i think only a couple of mm, so for example would work for 98mm to 100mm
pekwah1
and one last option, get the hubs redrilled!
pekwah1
loggyboy
posted on 1/9/10 at 08:53 AM |
Viva should be 100mm PCD surely?
rich201283
posted on 1/9/10 at 09:36 AM |
Nah pcd is 101.6 like the old mini's
I believe some people fit the 100mm pcd wheels, I seen one with astra wheels recently but i believe the studs bend and could be dangerous, anyone
drilled wheels before?
RazMan
posted on 1/9/10 at 09:42 AM |
I would have thought drilling the hubs is a better idea - drilling wheels is often impossible due to the shape of spokes etc
Raz
posted on 1/9/10 at 09:43 AM |
No, too old for that. It will have a 4 inch PCD, which is 101.6mm.
thefreak
posted on 1/9/10 at 11:13 AM |
I can get hubcentric bolt on adaptors/spacers made up if you wanted a set?
caber
posted on 1/9/10 at 05:22 PM |
I would have thought a big drill then some washers under the wheel nuts
Caber
[Edited on 9/1/2010 by caber]
omega 24 v6
posted on 1/9/10 at 05:30 PM |
There was a guy on ebay who would cnc up and spacer/pcd change you wanted at a price.
You can buy some spacers pcd changers off the shelf at merlin motorsport and other outlets.
Adaptors
rich201283
posted on 2/9/10 at 07:16 AM |
I dont really want to use spaces due to the bodywork, guess il have to look for some minilite alloys from a mini
