Author: Subject: Rv8 Engine mounts
Irony
posted on 4/9/10 at 05:58 PM Reply With Quote
Rv8 Engine mounts
I am looking to get some engine mounts for my Viento RV8. Alas I had a email quote from Luego for a £100 quid but now they haven't replied to my recent email trying to order some. I would phone but the guy there told me it is better to email!
Does anyone have any engine mounts? Bit hopeful perhaps. Or some dimension drawings of some suitable mounts for me to have them made. Also gearbox mounts.
[Edited on 4/9/10 by Irony]
tomgregory2000
posted on 4/9/10 at 06:02 PM Reply With Quote
land rover engine mouns on ebay.
ill see if i can find you any
tomgregory2000
posted on 4/9/10 at 06:04 PM Reply With Quote
get two of these
click me
Irony
posted on 4/9/10 at 06:05 PM Reply With Quote
Originally posted by tomgregory2000
get two of these
click me
Cheers but the rubbery bits are not a problem. Its the metal brackets.
Paul (Notts)
posted on 4/9/10 at 06:25 PM Reply With Quote
I made my gearbox mounts out of the cross member that is used to fit the gearbox into the sd1. I noticed you already have one of these attached to the gear box in a past picture
The Luego engine mounts are a simple design but effective.
not very good at drawings but could mesure mine up next week.
Paul
Irony
posted on 4/9/10 at 07:16 PM Reply With Quote
Paul
Did you have to do any welding on the gearbox mounts? I have two sets of gearbox Land Rover mounts so if theres no welding I could easy do it.
Regarding the Engine mounts I spoke to a Luego Owner at Newark who said he made his. But I can't remember the fellows name. He has a Black Viento V8 with Chequer Plate in the footwells and dual headlights. I was hoping he may have made some drawings.
Paul (Notts)
posted on 4/9/10 at 07:36 PM Reply With Quote
Sounds like Perci's Vinto. They made a lot of their own fittings.
Gearbox mounts simply involved an angle grinder and cutting the sd1 mounts down. will post a full explanation and pic later if you want but its now Beer time.
Paul
Irony
posted on 4/9/10 at 07:42 PM Reply With Quote
Paul
Cheers mate that would be awesome. Beer time!!! Have one for me, I am still at work and I have been at work since 6.30am! Boo!
Cheffy
posted on 5/9/10 at 07:36 AM Reply With Quote
Probably not much use if you don't weld but if you look on the 'chassis' page on my website about 3/4 the way down the page there's several pictures of how I did mine if it helps any.
Link to Chassis Page
Mart.
Farts are like Rock'n'Roll. You love your own but you hate everybody else's. Lemmy, Motorhead.
wilkingj
posted on 6/9/10 at 07:34 PM Reply With Quote
Pictures are in My Archive....
Gearbox:
Gearbox Rear mounting
I made a different design. The bracket on the engine, is a std rover part. I just made the sloping bracket bit:
Engine (Mine):
RV8 Engine mounting 3
Luego factory ones (Very simple to make, just use thick steel of 5mm min to stop them sagging like my original ones that I made from 4mm steel):
N/Side Engine Mounting
O/Side Engine Mount / Column
[Edited on 6/9/2010 by wilkingj]
Best Regards
Geoff
http://www.v8viento.co.uk
Irony
posted on 6/9/10 at 10:11 PM Reply With Quote
Has anyone got a set of these blue Luego Factory ones they could take some measurements for me?
Paul (Notts)
posted on 7/9/10 at 03:12 PM Reply With Quote
Yes...I can.
Will try this Sunday to get the dimensions + find some pics of my gearbox mounts.
send me a U2u on Sat to remind me or I may well forget.
Paul
wilkingj
posted on 15/9/10 at 11:39 AM Reply With Quote
If you are making the Luego Design,
Make sure you use thick enough metal.
The ones I made sagged (metal bent with the torque etc).
I recon 5mm at least. (I think I used 4mm)
This is why I changed to a different design on my Viento. I already had the original Rover brackets and only needed to make sloping supports.
Luego Design is fine.. just make them strong enough.
Personally I think there is less stress on the mounts that I made, as the Luego design is trying to lever off the bolt heads in the block.
Just my opinion.
Best Regards
Geoff
stevegough
posted on 15/9/10 at 08:55 PM Reply With Quote
Here's mine for an vauxhall XE-
Pic 1: target zone! - sorry - locostbuilders failing to upload this piccy?
Pic 2: components.
Pic 3: then I tack - welded them myself ('cos my welding was cr*p)
Pic 4: completed and painted.
Obviously, yours will be different, but the principle's the same.....
[Edited on 15/9/10 by stevegough]
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
wilkingj
posted on 16/9/10 at 06:54 AM Reply With Quote
Hmmm Thats a nice bracket, and I recon better than the Luego one, as it uses three bolts, and lessens the strain on the two that are in the block.
Good one... Typical of LCB.. There are always better ideas around the corner.
Chock the engine to the height you want, and just measure up. Thats what I did.
DO take into consideration Where your Exhausts are going to exit the side walls of the car.
EDIT: Damn Just realised ofs for an XE, not a RV8.
Still.... same principles apply. and make then strong.
[Edited on 16/9/2010 by wilkingj]
Best Regards
Geoff
SteveWallace
posted on 16/9/10 at 06:46 PM Reply With Quote
Steve,
I noticed in your pictures above that you have a bearing where the steering column goes through the foot well rather than the usual grommets. Do you have a link to where you got it from?
posted on 16/9/10 at 08:38 PM Reply With Quote
http://simplybearings.co.uk/shop/index.php
stevegough
posted on 17/9/10 at 03:36 PM Reply With Quote
Thanks, Rusty - quite a few of us got them at the same time - about £11 posted as I remember?
Luego Locost C20XE.
posted on 17/9/10 at 06:17 PM Reply With Quote
Something like that , made a huge difference to my car
SteveWallace
posted on 18/9/10 at 08:54 AM Reply With Quote
great, thanks for the link.
Once I get my account fixed so that I can post pictures again I'll do an update of my build progress
stevegough
posted on 18/9/10 at 07:00 PM Reply With Quote
Steve W you have U2u.
Luego Locost C20XE.
