Author: Subject: 893/919 Fireblade Spares
Bitsablade
posted on 5/9/10 at 11:02 PM Reply With Quote
I have the following 893/919 Fireblade Spares for sale:
Engine
    1x Head (complete - valves, shims, followers, head bolt set) - £100 +p&p
    4x Pistons (set of) - £40 +p&p
    2x Exhaust cams - £20 ea + p&p
    2x Cam sprockets - £5 ea +p&p
    1x Cam chain - £10 +p&p
    1x Cam chain tensioner - £5 +p&p
    1x Oil pump (w/ sprocket) - £10 +p&p
    1x Water pump - £10 +p&p
    1x Sump (standard) - £5 + p&p
    1x Oil strainer - £2 +p&p
    1x Oil pressure relief valve - £5 +p&p
    1x Oil pressure switch - £2 +p&p
    1x Starter motor idler gear (w/ shaft) - £5 +p&p
    1x Set of carbs (complete) - £60 +p&p
    2x carb choke brackets - £2 ea +p&p
    2x Idle-speed adjustment screws - £2 ea + p&p
    1x ITG filter + backplate (blade carb spacing) - £35 +p&p provisionally sold to fluidslvr
    1x Standard Airbox (only req filter) - £5 +p&p
    1x Bike Rad Fan - £5 +p&p
    1x Cam position sensor - £5 +p&p
    1x Pulse generator coil - £5 +p&p
    1x original reg/rec unit - £5 +p&p
Gearbox
    Complete set of selector forks (left, centre, right) - £40 +p&p
    1x Gear selector shaft - £10 +p&p
    1x Selector drum cam (w/ locating pin & bolt) - £5 +p&p
    1x Clutch pressure rod - £5 +p&p
    Set of original bike clutch springs - £5 +p&p
    1x original bike engine sprocket - £5 +p&p
    2x splined gearlever knuckles - £5 ea +p&p
    2x gearlevers - £2 ea +p&p
Other
    Mechanical shift set-up for BEC - £20 +p&p
I'm open to offers for the complete package.
All items can be taken to the Stafford kit car show (18th-19th Sept) for collection.
Photos of all items below:
[Edited on 6/9/10 by Bitsablade]
fluidslvr
posted on 6/9/10 at 05:22 AM Reply With Quote
U2U on the way...
http://mkmidi.blogspot.com
carpmart
posted on 6/9/10 at 05:25 AM Reply With Quote
Hi
I'm interested in a few bits but I need to know which year engine its off as the parts are different for example the water pump?
The bits I'm interested in are the water pump, carbs, rectifier and airbox. So first dibs please!
[Edited on 6/9/10 by carpmart]
'94 MX5 MK1, 1.8
F10 M5 - 600bhp Daily Hack
Mercedes A class - Son's Car
MK9R
posted on 6/9/10 at 08:46 AM Reply With Quote
Interested in selector drum and forks. what year exactly, and do they show any wear at all, i'e shiny bits or corners knocked of selector drum grooves?
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
Bitsablade
posted on 6/9/10 at 07:16 PM Reply With Quote
Apologies for the confusion - all parts are actually from a 919 blade, but I included the 893 in the title as some of the parts listed are inter-changeable.
fluidslvr - ITG provisionally sold to you (U2U on the way).
carpmart - First dibs is yours on the water pump, carbs, reg/rec and airbox (U2U on the way).
Austen - I'm afraid it's only the cam from the front of the selector drum rather than the drum itself. L&R selector forks have only very slight wear (C is unmarked), but I'll put up a high-res photo of each for you to look at and see what you think.
Thanks,
Mark
carpmart
posted on 6/9/10 at 07:36 PM Reply With Quote
Hi Mark
Not received the u2u?
'94 MX5 MK1, 1.8
Bitsablade
posted on 6/9/10 at 07:53 PM Reply With Quote
Try now
Bitsablade
posted on 8/9/10 at 10:07 PM Reply With Quote
ITG filter + backplate sold to fluidslvr
Must be some more 919 blade owners wanting spares...
Bitsablade
posted on 17/9/10 at 10:46 PM Reply With Quote
Update:
Both splined gearlever knuckles sold to Joni.
Water pump and original Reg/Rec sold to Carpmart.
All other items are still for sale and will be available at the Stafford Kit Car Show tomorrow (Saturday).
Bitsablade
posted on 20/9/10 at 08:54 PM Reply With Quote
All remaining spares still for sale - I'm open to sensible offers for the more expensive items...
Bitsablade
posted on 26/9/10 at 09:17 PM Reply With Quote
bump
Bitsablade
posted on 4/10/10 at 11:46 AM Reply With Quote
bump
Bitsablade
posted on 14/10/10 at 12:16 PM Reply With Quote
bump
Bitsablade
posted on 22/10/10 at 11:55 AM Reply With Quote
bump for the weekend
Bitsablade
posted on 29/10/10 at 10:04 PM Reply With Quote
bump
Bitsablade
posted on 5/11/10 at 10:09 PM Reply With Quote
I'll take £150 for everything still for sale...
Bitsablade
posted on 13/11/10 at 01:21 AM Reply With Quote
Update
Now Sold:
- 1x ITG filter + backplate (blade carb spacing)
- 2x splined gearlever knuckles
- 1x Water pump
- 1x original reg/rec unit
- 1x Head (complete - valves, shims, followers, head bolt set)
£80 + p&p for everything else listed in OP!
Bitsablade
posted on 20/11/10 at 05:42 PM Reply With Quote
bump
Bitsablade
posted on 10/12/10 at 12:50 PM Reply With Quote
bttt
