mangogrooveworkshop
posted on 6/6/04 at 06:43 PM |
small alternators
http://www.racemettleltd.co.uk/alternators.html
PowerLite lightweight Alternators are designed to reach into places "others" cannot! Weighing in at a skinny 3 Kg, and around 115 mm in
diameter, these little alternators will help solve the eternal space problem many constructors have.
All PowerLite alternators are fitted with Single Wire connections as standard, have internal regulators and an integral system that draws air through
the unit for cooling.
With 4 different bracket designs, lightweight pulleys in any dimension, and charging at a plentiful 45 or 55 amps, although up to 100 amps is
possible, we are confident that one of our units will fit into any car.
greggors84
posted on 6/6/04 at 07:04 PM |
Any prices on these?
Chris
The Magnificent 7!
Mark Allanson
posted on 6/6/04 at 08:12 PM |
I just bought an alt from the scrappies, Kia Pride ('92), its only 120mm diameter, 130mm long and the lugs are 12 & 6 o'clock - cost a
fiver.
Still need to figure out how to wire it though!
SeaBass
posted on 6/6/04 at 08:15 PM |
Talking of alternators and having just had some fun at the scrappy getting bits for our Zetec conversion this might be useful and in the Locost
spirt.
I removed a Nippon Denso alternator from a Suzuki Swift. This thing is tiny and contains it's own regulator. I believe this is the same as the
Daihatsu Charade alternator people talk of. If you take a look in the Demon Tweeks catalogue they list 'Brise' competition altenators
which are the same unit brand new at £169.
Strangely enough this little alternator is rated at 45 amps?? See a link here describing an install.
http://home-1.tiscali.nl/~svos/alternator.html
Mr G
posted on 5/12/04 at 12:40 AM |
yup that Nippon denso alternator is the baby to use.
We got ours from a daihatsu charade in the scrappies then went to a local lucas centre and got a pulley wheel to fit it that would take the vauxhall
belt.
Wiring :
You obviously have the main live out to the starter (then onto the battery) Pin 3
Then the two terminals in a 'T' configuration
Pin 1 is your battery charge warning light
Pin 2 is a + feed from your ignition
HTH
G
[Edited on 5/12/04 by Mr G]
Trev Borg
posted on 5/12/04 at 02:25 PM |
are there any smaller ones. I'm getting a little tight for space.
I'm sure that alternators fromplant have been metioned before. Mini diggers and alike.
Also I've been told that one on the mitsubishi cars has a really small one (uh err)
Before you judge a man, walk a mile in his shoes.
By that time, who cares.
You're a mile away, and you've got his shoes
posted on 5/12/04 at 03:34 PM |
Brother in laws mini digger uses the same nippon denso as those shown. I've seen them used on refrigerator truck motors as well. The only things
I've seen that are smaller come in motorbike engines.
Mr G
posted on 5/12/04 at 07:53 PM |
You aint gonna get much smaller than the Nippon Denso shown to be honest (at a reasonable cost anyway) and also still produce a half decent output!
I'm not sure if the photo is making it look bigger than it actually is
Failing that forget the alternator and buy a lorry battery you charge up in the garage regular
G
mad-butcher
posted on 6/12/04 at 07:51 PM |
dihatsu charade ,suzuki vitara as mr g says you ain't gonna get much smaller about half the size and half the weight of the ford one I pay about
a tenner for them at the scrappy
Trev Borg
posted on 6/12/04 at 08:04 PM |
looks like I'm gonna be top mounting mine, or maybe face it backwards. The bloody great big V6 thing is tending to take too much of me room.
