Author: Subject: Sierra wheel bearing kits
shortie
posted on 7/9/10 at 07:46 PM Reply With Quote
Have two of these which I no longer need, brand new in boxes.
The pair can be yours for £10
Rich.
big_wasa
posted on 7/9/10 at 07:54 PM Reply With Quote
front or rear if rear I will take them please.
[Edited on 8/9/10 by big_wasa]
steve8274
posted on 7/9/10 at 07:58 PM Reply With Quote
2nd dibs please. only need hub nuts really
steve
big_wasa
posted on 7/9/10 at 08:03 PM Reply With Quote
if there complete rears I will send you the two nuts I have
mcerd1
posted on 7/9/10 at 08:31 PM Reply With Quote
I think I've got a spare set of nuts for the fronts (one left one right)
steve8274
posted on 7/9/10 at 08:41 PM Reply With Quote
thanks big wasa. take it they are unused? i want new ones since i was told not to re use old nuts once removed. like nylocs
mcerd1. i need rear ones. thanks for offer
steve
big_wasa
posted on 7/9/10 at 08:51 PM Reply With Quote
No they are used. haynes recomend they are aonly reused upto five times. They are not nyloc's
steve8274
posted on 7/9/10 at 09:02 PM Reply With Quote
mine are truly knackered. must have been on and off few times before me then.
my hub nuts have coloured nyloc style inserts at end of nut. green and white. these same as yours?
i will take them and try if you dont mind, thats if it is a full set for sale and if they reply to you
steve
mcerd1
posted on 7/9/10 at 09:08 PM Reply With Quote
all the sierra/granada ones I've had have been nylocks (old & new, ford and aftermarket)
the aftermarket ones have all got white inserts, but a mark/ notch on the outside of the lefthanded ones
big_wasa
posted on 7/9/10 at 09:24 PM Reply With Quote
Looks like mine are early ones as they are the staked type and both are m22x1.5 and are both r/h thread.
thats what you get when you buy random odd parts instead of a donor.
So no good to you.
steve8274
posted on 7/9/10 at 09:32 PM Reply With Quote
correct. no good to me. however, if you get these bearings and they have nuts like mine which will be no use to you, please let me know
thanks
steve
steve8274
thanks
steve
