Author: Subject: Brake Pipe Size?
nnrouty
posted on 9/9/10 at 11:02 AM Reply With Quote
Brake Pipe Size?
Hi all
using standard sierra braking system on my project, cant anyone tell me what size pipe will be suitable for this setup?
Also, which sierra's used vented discs on back?
As long as its fast.... i don't care
mrwibble
posted on 9/9/10 at 11:15 AM Reply With Quote
brake lines are a standard size from motor factors, its 3/16" irc.
discs on the back came with optional abs models, and were mostly fitted to 2.0l pinto or i guess dohc engined cars. ur common all garden LX models had drums
P.S search feature will prolly tell you all this
[Edited on 9/9/10 by mrwibble]
tomgregory2000
posted on 9/9/10 at 11:20 AM Reply With Quote
VENTED discs on the back were fitted to cosworths
nnrouty
posted on 9/9/10 at 11:36 AM Reply With Quote
thanks for help
carlknight1982
posted on 9/9/10 at 11:50 AM Reply With Quote
i think also there was some diffrence between the disc carriers for vented and solid rear discs although i could be wrong.
Logic will get you from a A to B
Imagination will take you everywhere.
