Author: Subject: sierra hub nut torque
femster87
posted on 13/9/10 at 07:47 AM Reply With Quote
noticed in the haynes manual the torque on the upright is rated to be between 310 -350nm. My bench cant take that. but i think its hell of a lot of torque. is this what everyone has used?
posted on 13/9/10 at 08:23 AM Reply With Quote
That's correct. Best done in-situ using the weight of the vehicle to hold them still.
Are you doing them up or undoing them on the bench?
Search for recent posts by "coozer" with a tip for doing it off the vehicle.
snapper
posted on 13/9/10 at 08:39 AM Reply With Quote
Fit and tighten on the bench then put the full torque on once fitted to the car
I eat to survive
I drink to forget
mcerd1
posted on 13/9/10 at 09:03 AM Reply With Quote
its a big torque, but thats the preload the bearings need to work properly...
femster87
posted on 13/9/10 at 09:14 AM Reply With Quote
took it into work to try and get it torqued up this morning. everybody in the workshop thinks am mad. and that haynes was a typo. so i had to check.
col
posted on 13/9/10 at 04:42 PM Reply With Quote
My Haynes manual for rear hub nuts states: 250/290Nm or185/214lbf ft.......i used to have a aircraft torque wrench with 12ft handle,used to torque propellars....well you wouldnt want them to come off would you?
femster87
posted on 13/9/10 at 05:15 PM Reply With Quote
yeah true, sorted now thanks.
mcerd1
posted on 13/9/10 at 07:21 PM Reply With Quote
if haynes are wrong then so are autodata and ford
the sierra bearing might come in 4 bits, but they arn't the same as the older adjustable ones....
