phelpsa
posted on 20/9/10 at 10:06 AM |
No neutral?
Neutral has disappeared When the engine is on and you go looking for neutral, its not there. Turn engine off and it's easy. What's
likely to be causing this?
BobM
posted on 20/9/10 at 10:19 AM |
Dragging clutch?
Not very Locost but very BEC
steve m
posted on 20/9/10 at 10:20 AM |
I was going to say that !!
i presume its a hair drier engine ??
daviep
posted on 20/9/10 at 11:37 AM |
Has it always been like this or has it suddenly changed?
Not an uncommon problem on some bikes.
phelpsa
posted on 20/9/10 at 11:58 AM |
Always been awkward, only recently become difficult and then impossible. Will take a look at the clutch
MakeEverything
posted on 20/9/10 at 12:57 PM |
Could just be some slack in the selector mechanism. Check the cable / rods first. Quite often if its too sloppy, youll never find the half gear.
Kindest Regards,
Richard.
Chet
posted on 20/9/10 at 01:17 PM |
Like everyone else suggests -
Clutch adjustment is the most likely issue.
Chet
