Author: Subject: Where to get T-peices for cooling system
Jasongray5
posted on 22/9/10 at 09:23 AM Reply With Quote
Morning Chaps,
Just wondering where I would go to get T-peices for my cooling system? Done a few searchs but no luck? Think they want to be around 32-19-32 and the like.
Many thanks. Jason
How hard can it be?
http://www.flickr.com/photos/33261515@N03/sets/72157611049241239/
RazMan
posted on 22/9/10 at 09:26 AM Reply With Quote
CBS did mine to order - good job too.
Raz
Macbeast
posted on 22/9/10 at 09:48 AM Reply With Quote
CBS again
Bluemoon
posted on 22/9/10 at 10:15 AM Reply With Quote
Yorkshire plumbing fittings for locost..
shortie
posted on 22/9/10 at 11:05 AM Reply With Quote
I used some from pond supply shop IIRC, do loads of different sizes and cheap.
HTH,
Rich.
dhutch
posted on 22/9/10 at 11:52 AM Reply With Quote
Id go with CBS.
Cooling loops are going to be circa 100deg c and under pressure. I wouldnt want to be using pond fittings for that.
stevebubs
posted on 22/9/10 at 12:03 PM Reply With Quote
Allyfab will also do them to order
posted on 22/9/10 at 12:14 PM Reply With Quote
I got 32 equal tees from a fish pond hardware supplier used them for Rover thermostat conversions, stand up to the heat and pressure fine.
They also do 25 equal Tees.
Gergely
posted on 22/9/10 at 01:13 PM Reply With Quote
I had a similar issue, searched and they were mostly too expensive solutions...
So I went to the scrapyard and bought a big bagful of different cooling tubes, different diametres, T-pieces, Y pieces, curved pieces... It all cost me 10 pounds and it's perfect for the job...
Our build pictures
posted on 22/9/10 at 04:28 PM Reply With Quote
Scrapyard source Rover 75 has an unequal tee (ISTR 32x32x19) going into the bottom hose from the header tank. No longer available from Xpart Rover as a new part.
