Author: Subject: Audi A8 Fuel pump
David_17
posted on 29/9/10 at 02:52 PM Reply With Quote
Audi A8 Fuel pump
I bought a fuel pump new off ebay advertised for kit cars.
I emailed the seller, he told me they are from Audi A8s.
It came today, one end has a normal 8mm fuel connection and the wiring terminals. The other has a 20mm connection with a small filter inside.
Can anyone tell me where to find some 20mm fuel hose, and has anyone used one of these?
Hope it's not designed to go inside the tank
David_17
posted on 29/9/10 at 03:03 PM Reply With Quote
Here's some pics.
Anyone know what the 2 small holes are near the 19mm inlet? :S
ko_racer
posted on 29/9/10 at 03:04 PM Reply With Quote
You'll probabl needs some adaptors, but Merlin Motorsport have a good selection of hoses and fittings.
Looks like an in-tank pump to me too.
[Edited on 29/9/10 by ko_racer]
RazMan
posted on 29/9/10 at 03:45 PM Reply With Quote
That looks like a Walbro in-tank jobby to me - I had one of those (or something very similar) in my 200SX. The inlet usually has a sock filter attached which might be what the two holes are for.
[Edited on 29-9-10 by RazMan]
Raz
David_17
posted on 29/9/10 at 03:48 PM Reply With Quote
So if i stick a pipe on the 20mm connection, it's gonna suck air in the 2 holes?
RazMan
posted on 29/9/10 at 03:58 PM Reply With Quote
Nope, I reckon that's the outlet so the two holes might be for mounting to the in-tank bracket.
Raz
David_17
posted on 29/9/10 at 05:25 PM Reply With Quote
Well, had a bit of a play in the sink with a 12v power pack and it's an in-tank one
No good for any kit car/custom as it was described as in the title of the listing on ebay!
Now, need to try and sort a replacement.
sebastiaan
posted on 30/9/10 at 07:01 AM Reply With Quote
That's and in-tank pump. The two holes are vapour returns from the pump element.
