Author: Subject: Starter and Ignition switch questions
Antnicuk
posted on 30/9/10 at 09:40 PM Reply With Quote
I am currently using a universal wiring loom and ignition switch but i dont think that the wire supplied is thick enough to supply the coils with the right amount of current. The coils are quite big and very demanding. I have had an issue with my coils that is intermittent.
The stock mazda ignition and wiring sends a 5mm wire direct from the ignition barrel to the coils. Some alarms fitted to rx7's can cause problems when the ignition feed is cut and the alarm wire bypassing th circuit is too thin. This can cause the engine to die if not addressed.
I either need a heavy duty ignition barrel and replace the wire going from the power source to it and also the wire going from it on to the coils. The other option is to leave all the wires in situ and run a new thicker power wire direct from the battery through a relay to the coils which uses the original wire from the ignition switch as the signal to switch power to the coils.
I just wondered if the relay method would be ok on coils or if anyone had any idea's on what i can use. The car is mainly a track car so i dont really need keys but i would like something a little more subtle than the big red isolator switch.
Any assistance much appreciated.
600 BHP per ton, Stylus Brought back from the dead! Turbo Rotary Powered!
hearbear
posted on 1/10/10 at 08:47 AM Reply With Quote
The relay route is probably the easiest way to go just use a good quality relay with a high amp rating so the contacts will not give any problems not a cheap crappy one
George
3.9Ltr SSC Stylus should be fun
David_17
posted on 1/10/10 at 11:03 AM Reply With Quote
I agree, a relay's the best solution in my opinion too.
Antnicuk
posted on 1/10/10 at 02:06 PM Reply With Quote
Thanks guys
any ideas how i can tell a good quality relay or where to get one from?
[Edited on 1-10-10 by Antnicuk]
hearbear
posted on 1/10/10 at 06:23 PM Reply With Quote
Linky
Branded and high amperage
Cheers George
Antnicuk
posted on 1/10/10 at 09:39 PM Reply With Quote
Thanks George.
